Hitachi 61SWX10B 61" Rear Projection Television Logo
Posted on Nov 22, 2008
The color convergence seems to be on the fritz. all of the images on the screen have red blue and green shadows around them. I have tried the magic focus syste
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
118
Points
I have a 61swx10b hitachi. Cable one was moving my television around and it started with color shadows and then went dead with the power button blinking after that. RK42 looks overheated and RK50/RK58 are burnt. RK42 looks like it is a 11 ohm (brown/brown) resistor, but reads 1 ohm in the circuit. Are they all 11 ohm resistors. Also the IC's you are referring to are STK392-110 right.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
11196
Points
8
Replace the convergence ic's. You will also find several burned resistors in the same area that need to be replaced.
Mitsubishi RPTV has a blue shadow/image alignment problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
The right side of the TV has shadows/distorted images and colors
  • Screen looks 3D
3helpful
HITACHI 57UWX20B has blue ghost shadows how do I
  • Screen looks 3D
Color and Image are Bad!
Convergence IC's are bad or poor solder connection, IC's are large chips with heatsink mounted to them, re solder them to board, if not fixed replace IC's, should be 392-110s, but check them number is on the IC itself.
Problem with RGB color...registering as green and image distorted
did u fix your tv cuz thats the same thing thats happening to me
Green shadowing
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Hitachi television repair
Try switching the power off at the PLUG for the night. This will allow the screen to reset. I had a similar problem after a power failure.
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
26helpful
10answers
how do i access the convergence on my big screen
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
