Canon Rebel XT / EOS 350D Digital Camera Logo
Anonymous Posted on Feb 13, 2018
Canon Rebel XTI Flash issue
When I depress the button to take pics the flash pops up but no light...there is not flash and all my photo's are dark.
Anyone know how to possibly fix this. I have never used external flashes or add ons at all.
I am a basic user that loves the quality of this camera.
  • 4 more comments
  • mgknight9260 Dec 19, 2008
    My flash won't even pop up. It just makes a clicking sound. Sent it in to Canon to get it fixed last year while still under warranty. They "fixed" it, but now it is doing it again. Sent it back to Canon & they want $230 to fix it. Someone else I know has this same problem with her camera. She just uses an external flash. Would cost about the same to get the camera fixed as it would be to buy an external flash.
  • debbiehilz Jan 12, 2009
    I have the same problem - my flash pops up, but the light does not fire off and all my pictures are very dark when trying to use the flash. I tried the external Speed Lite, but it will not fire off either.
  • shannon912 Jan 16, 2009
    I have the same problem...the flash will go off and then goes off again about 4-5 seconds later. the pictures are coming out extremely dark.
  • Anonymous Feb 08, 2009
    I'm having the same problem. I've had my camera for a couple of years and have been very happy with it. Just recently though my flash opens but does not go off. :( Took it to a local repair place and they told me it was broken. duh. I need more. Any reset buttons? Setting issues? Please let me know if there are any trouble shooting steps that can be tried.
  • SHILORAVINN Feb 22, 2009
    I have the same problem - Canon Rebel XTi flash pops but won't fire. Shop offered to "look" at it for $128...
  • Anonymous Feb 24, 2009
    I have the same problem. I was taking pictures inside last night with my Rebel XT; it was fine for about 10 shots, then the flash stopped working. I have no clue what's goin on. Any help would be appreciated
cesarakg
Level 2:
New Friend:
  • Expert 26 Answers
  • Posted on Sep 25, 2018
cesarakg
Expert
Level 2:
New Friend:
Answers
26
Questions
0
Helped
14323
Points
113
Maybe there's a problem with your camera's pop-up flash.
Contact Canon Customer Support, and see what they can do for you. Probably they will point where you can get your camera repaired.
5 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Jul 22, 2007
SOURCE: built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
Anonymous
  • 9 Answers
  • Posted on Feb 19, 2008
SOURCE: xti rebel 6 mths old - flash will not pop up
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Anonymous
  • 9 Answers
SOURCE: No flash popup on my rebel XTI
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Anonymous
  • 9 Answers
SOURCE: Flash doesn't work
Anonymous
  • 398 Answers
  • Posted on Aug 06, 2008
SOURCE: rebel xti camera materials
Check out canon's web site for downloads of what you need.
I have a canon rebel xti and the flash pops up but doesn't flash even when its dark this is when the setting is in full auto. any ideas? could the "bulb" have broken?
The short answer is yes, that is possible. It's also possible there is a circuitry problem. You will want to verify by trying to use an external flash and making sure it still works. The flash assembly is replaceable if needed.
Thank you.
2helpful
Canon Internal Flash will not Pops up and will not flash. Is there something I can check for or replace? I have a cannon rebel xti, the external flash works great, the button to make the flash pop up will...
Is it trying to pop the flash and making noise, or is there no noise at all?
If it's audibly trying and it won't pop up, it's stuck and something is blocking it. May need to send it in.
If there is no sound, then something is making it think that there's an external flash attached. Check out this photo here:
http://www.flickr.com/photos/dougpardee/133066175/
Doug Pardee on flickr may be able to help as well.
Hope this helps you! If so, leave me a rating!
Canon rebel xti flash pops up but says it was obstructed
This is a problem known by Canon, you will have to have it serviced.
Canon xti and canon 420ex flash giving
Make sure the 420EX is set to E-TTL and set the camera to "P". If is need of more light, increase flash exposure to +1 or 1.5.
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
1helpful
Why does the word, ''busy'' pop up on the canon rebel xti?
If the flash fires a full charge(eg. in a dark environment) then this message will appear whilst it recharges. If the message appears all the time and you cannot take a photo there is most likely a problem. Try taking some pictures without the flash card to eliminate that first.
Built-in flash does not work
DO NOT MESS with a new camera (or any other new equipment).
Take/send it back to the vendor, The purchaser has rights also. Number one it must work.
I don't know your location but in UK (& Europe) we have very strict consumer legislation.
1helpful
2answers
Flash
3answers
How to switch on Auto Flash in Auto mode
Put the camera in "P" and press the flash button above the lens release. If the flash pops, than you probably just have too much light to need it when you are in auto. The flash button is not active in auto so if the xti doesn't want the flash in auto, u can't make it fire. If the flash button does not make the flash pop in "P", search this site for another post about flash not working and u will find that this could be the flash deactivation button in the hot shoe sticking. Not likely though with a new camera unless u have had a speedlite mounted alot.--
1helpful
2answers
Flash doesn't work
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
