Idles around 600 - 700 RPM while not in gear. Once in gear, very rough idle with vibration. Hesitates accelerating up to 20mph and then at 25, 30, 35, etc. Runs relatively smooth once accelerated to about 35 though still feel some vibration. Replaced plugs/wires (coil boots), throttle position sensor, and IAC sensor, cleaned throttle body, and added fuel injector cleaner. Not receiving any codes. Prior to replacing plugs, TPS, and IAC, received codes 0300, 0301, 0304, and 0204.
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
---------How to adjust rpm?
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
------------Engine cuts out at 3000
RPM?
http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
----------This will help.Thanks.
Where might I find a vacuum line diagram?
Did you find a solution to this?
