This is stopping it from running, almost tottally
SOURCE: oil leaks from breather box
Hi!
From your brief description It sounds like you are experiencing Crank Case pressure build up.
I presume your ZZR is of High mileage or possibly previous owners havn't serviced it regularly.
The problem being the compression Piston Rings wear and allow Blow Back gasses into the crank case there by building up pressure, this in turn sends an oil film up the breather tube to your air box resulting in your problem.
You could try an oil & filter change (Synthetic) Top jolly with maybe an additive plus similar for the fuel i.e. Red-Ex or similar, it may help but I doubt a cure.
If you want you could extend the breather pipe away from the box into a drip can or similar, be sure to filter it as you don't want to get contamination down in the cases.
Hope this sorts it for you?
Please press the Blue Button for appraisal of my FREE! Effort.
Thank You! & Good Luck.
Paul 'W' U.K.
SOURCE: breather pipes on honda vrf 400
probably up underneath at the front of tank. like where the higest part of the tank tunnel is.
SOURCE: oil breather problem
keep your oil breather unblocked all the time's coz the pressure of it can destroy your gasket and oil seal.
SOURCE: 2003 honda shadow spirit vt750 carb problem
buddy dont worry about it what you have done is put to much oil inside the engine and as the piston goes down it cause abit off pressure which in the small space it has when you over filled it the pressure inside has just forced the oil out the breather into the air box just give it a little clean and drop oil aswell bud
Testimonial: "Thats Great news. Yup just like you said I drained all the oil, put in the right amount & cleaned the intake chamber and its running great now.THANKS!"
SOURCE: oil blowing out through air-filter,rough
Your '98 Evo motor is what they call a "head breater" engine. This means that the crankcase ventilation is at the upper end of the heads rather than way down at the lower end of the engine like it used to be. They the first year for the "head breaters" was 1994.
Now, At the top of the heads where the rocker boxes are, there are three pieces. The lower rocker plate with the rocker arms in it, the middle piece and the upper cover. If you take the four bolts out, you'll see an umbrella valve in the middle piece of the rocker boxes. This valve is a replacable rubber piece. Over time and many times of heating up and cooling down, they can get brittle and allow a lot of blowby resulting in oil in your air filter element.
Now there is another part in the cam chest that has a lot of effect on the operation of the crankcase breather system on your bike. This part is called the "breather gear" and is located down in the cam chest to the rear of the camshaft. In you bike, the part is made of plastic if it's the original part. I have seen the teeth break off of the drive gear and the breather gear stop turning. This will screw up the "breathing cycle" on your engine and cause it to "blow oil". Usually, the oil pump locks up when this happens due to the plastic teeth getting in the oil pump but not always. If this eventually turns out to be your problem, have the mechanic or yourself install one of the new S&S reed valve type breather gear replacements. They don't turn at all and work absolutely great. The part is about a hundred dollars but it's well worth it. Solves the old broken breather gear problem that has plauged the Evo engine it's entire life.
There are no "screens" in the Evo engine other than the "tappet oil screen". Just in front of the oil pump is a screw plug that is in the engine cases itself. If you remove this plug, there is a small spring and cone shaped screen that filters the oil prior to it going to your tappets. This should be cleaned every other oil change but it has nothing to do with the oil in your breather.
Now some riders will tell you that if you allow your Harley to sit for any length of time that it will "oil sump" with you. By this, they mean that oil will seep past the check ball in your oil pump and pool up in your crankcase. When you start the engine up, oil will be blown into your oil filter. Not true on your Ultra. The bikes that will oil sump are the Sportsters, Softails, Shovelheads, or any bike that the oil tank is higher than the oil pump on the frame. On your Ultra, the oil tank is on the bottom of the transmission. Your bike will not "oil sump" unless you have a sheared key in your oil pump or the oil has somehow learned how climb. You oil tank is below your pump in other words and oil does not flow uphill.
sounds like a busted ring or it is frozen in place
