Question about Sony Video Game Consoles & Games
My ps3 controller doesn't respond to the ps3, all
  • 6 Answers
If the controller is Sony you can just go the store you bought it at and exchange it But if u got a controller not Sony brand then recommend you not to buy cheap brands bc they break fast . Buy Sony products will last longer
Posted on May 14, 2012
2 Suggested Answers
SOURCE:
  • 35 Answers
SOURCE: When using my PS3 COD
It sound like the controller is faulty. I suggest returning it. with PS3 controllers 3 party brands tend to be cheaply built. Its best to buy sony's controllers.
Posted on Mar 02, 2011
Brand new Sony dual shock 3 analogs not responding like my other ps3 controllers
Take it back to the shop if it is under warrantee. Don't mess with it and destroy your warrantee.
Mar 11, 2014 | Sony Dual Shock 3 Controller for...
Ps3 joystick
calibrate controller ? check controller settings ?
Dec 30, 2013 | Video Game Consoles & Games
SYSTEM DOESN'T RECOGNIZE CONTROLS HOW DO I FIX
I'm guessing the issue is that the PS3 isn't responding to your controller input.
Ensure that the PS3 controller is actually on. You can turn on the controller by pressing the Playstation button in the center of the controller. There will be a red light on top of the controller indicating that it is on.
If no light shows up, it's possible that the controller simply has dead batteries. Grab your controller charge cable (should have been included with controller, looks like this) and connect the controller to the PS3 while the console is on. Give it a few minutes, then press the center Playstation button again and see if it responds.
It's also possible that the controller just isn't synced to your PS3. Again, grab the charge cable and connect it to your PS3 while it's on. Then press the Playstation button while the controller is connected. It should sync it to the PS3.
If none of that is working for you, there may be an issue with the controller itself. The easiest fix it to reset the controller. There should be a tiny button in a hole on the back of the controller. Just press it (you'll need a paperclip or something to do it) and the controller will reset. I believe you'll have to re-sync the controller (using the cable again).
You should also try syncing other controllers to your PS3 to make sure that the issue isn't with the PS3 itself (which would be awful; I've never heard a PS3 breaking like that but I suppose there is always a first). If other controllers work then either your controller's battery is dead or the controller is actually broken. I don't think Sony repairs/replaces controllers so you may have to buy a new one.
It may be worthwhile to checkout their support page first, to see if anything helps before shelling out 50$ for a controller:
Sony Support
Sony Repair
Amazon - PS3 Controllers (I recommend Silver; it's ****).
Hope it all works out!
Sep 01, 2011 | Sony Playstation 3 (PS3) Console
I bought my ps3 in london and now im in Paris the ps3 turns on but wont turn off and it doesn't show up on the screen and the controller keeps on beeping none stop
Easy to solve, the way to turn off the ps3 is simply hold the power button until you hear one beep, then let go. That way you wont have to go to the menu, and your controller beeps because it is low on battery try using a charger that connects to the ps3
Jul 06, 2011 | Sony Playstation 3 (PS3) Console
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
When using my PS3 COD Black Ops precision controller on other games,... movement of the left analogue stick to the Northwest position has no effect in game , neither does movement of the right analogue...
Mar 02, 2011 | Mad Catz Call of Duty Black Ops...
My Intec PS3 Turbo Shock Wireless Controller wont sync to my ps3. it is useless. i dont know what else to do. i have never dropped it. it was working fine one day and the next day it did not sync to my...
I've gotten mine to sync fine just follow the steps but press and hold the sync button for like 5-10 seconds. To be honest the best thing you should do is to refund it because mines already broke, cat knocked it over and now I have no vibration..... I've had it for less than a day, both analogue stick move by themselves in game which to me seems like the f*cking thing is demonic and sucks hardcore playing online.Also the sticks arent sensitive they'll jump over things when you move them and add the automoving analogue sticks that your constantly fighting with just makes things like hell Save your money for a higher grade model!!!!
Oct 23, 2010 | Intec PlayStation 3 Turbo Shock III...
My controller is original dualshock3,...the stick and the pad when i turn on the ps3 on the xmb menu it rapidly goes stuck to the left any ideas before i buy another ps3...HURRY!!! i won't hold much...
Have you tried using a different controller? Usually this is the problem, your PS3 controller's D-Pad is stuck on the left side or the responding piece beneath the D-Pad is being pressured down in some manner. I recommend trying a Different controller first before buying another PS3 ( get a cheap PS3 Arcade stick or something)
Nov 17, 2009 | Sony Wireless Controller for PS3
Cant make the analogue sticks to move character in game
open up the controller and tact the anolage stick off and clean it.
Jun 20, 2009 | Logitech Rumblepad 2 Game Pad
Sixaxis controller turns left
The solution is simply to buy a new controller, or get a cheaper one like 'madcats' or 'Logitech' which is about half the price of the SONY brand.
But you need to consider this if buying a brand other than SONY;
it might not last as long maybe about 6 months-a year before it gets funny with the controls. Also, most of them needs a USB receiver and batteries for the controller to use wirelessly for PS3. Which I think is troublesome, cause you can't charge it like the SONY dual shocks, and have to spend more money for new batteries or rechargables. You also need to sacrafice a USB slot on the PS3 for the receiver to work wirelessly with the controller, and I have no idea what the response is like when playing games, it might not play as smoothly as the original SONY Dual Shock.
May 01, 2009 | Video Game Consoles & Games
Video Game Consoles & Games Logo
90 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
