Lexmark Interpret S405 Wireless All-in-One Printer w/Copy/Fax/Print Logo
Anonymous Posted on May 12, 2012
Printer does not detect original - Lexmark Interpret S405 Wireless All-in-One Printer w/Copy/Fax/Print
Anonymous
Level 3:
Genius:
  • Master 1,087 Answers
  • Posted on Aug 27, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1087
Questions
0
Helped
490666
Points
2129
Try to update your printer firmware http://bit.ly/t7sPJR . Feel free to contact us if you're still having problem.
ADF original size sensor doesn't work so that I can't copy A3 format via ADF
Did you run the Original Size detection tray procedure? That is done in service mode. Counter, details, stop 00 stop 01, ADF, original size detect MAX and MIn. Max the original guide to the back for min. guides to the center.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Windows 7 epsom sx515 printer, driver detective installs sx510 driver
Please. Do NOT rely on 'Driver Detective'.... !!!
Just un-install the software from this and the driver and download
and install the original Epson SX515w printerdriver and software!
1helpful
I got the manual for my J3680 all in one printer, BUT
Hello
It sounds like the scanner/fax is not seeing the original document that you want to scan or fax.
Per Page 20 of the User Manual, the original needs to be placed face down in the document feeder. (The document feeder is on the top of the printer, behind the display.)
When you insert the original, make sure the leading edge is sliding into the top of the printer (towards the front of the printer).
Per the user manual, you should hear a beep and/or see a message on the display stating the loaded pages were detected.
If you are not hearing the beep or seeing the message, your original is not loaded correctly - try sliding it further into the printer.
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
I get a message the catridge inserted is not intended to use with this printer
HP has embeded tools to detect if you are using the original HP cartridge or not in their printer driver.It detect fake catridge & display message to the user.That is the message you are encountering.Avoid using fake catridge for long printer life and good quality printing.
The function detecting the remaining ink level is disable
Hi, are you using Original Canon supplies or are the cartridges you are using are refilled/ or non-canon supplies? If they are not original Canon supplies I'm afraid the use of the "ink gauge" is one of the features lost when refilling your cartridges or using non-original supplies. If you get a new set of supplies (Canon branded) the gauge should work again .
Epson LX-300+
did you share printer on Main PC ( the PC where are the original drivers )?
Under printer properties, mark "share printer" and apply and ok.
Hope tha helps!
3helpful
How do I re-enable the ink level monitor on my Canon iP4200 printer?
Hi jskaff,
Did you mean 'activate ink level detection function' of this printer?. Did you deactivate this function before?. Did you refill the ink tank?. Well, ink level detection function will active automatically when you replace the ink with new original one.
Regards,
2answers
Ink
Better not to refill. Better buy a new original Canon cartridge. The reason being that some of the newer printers have sensors which can detect refilled cartridges and will cause more problems later.
Ink problems
Your printer an " original ink " manufacture by lexmark printer don't use genirec printer connot detect.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
