? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax. 2. Touch Send Now. 3. Touch the telephone symbol to access its phone book feature. 4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts. (Note: Contacts should be established before any of these could be added to any group.) 5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group. 6. Touch Name. 7. Changes to contacts/groups: •Adding a contact/group: type the name, & then touch Done. ••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create". ••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then... ••Editing a Contact: touch Fax Number, enter the fax number, & touch Done. ••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Its ether the toner cartridge or the fuser. send one page to the printer and open the cover when the page is under the cartridge. Pull the cartridge out and look at the page. If you can see the line its the cartridge if not its the fuser. I think its the cartridge.
Thank you, Steven 805-520-3003
if you are getting a paper jam message but you can not find paper any where in the printer the first thing that you want to do is clean the pickup roller in the paper tray. the roller is located on the top of the cavity that the paper tray is installed in.
turn the power off.remove ink cartridge then check there is not any paper jam.aslo check in back side of printer for paper jam .also clean your ink cartridge try other ink cartridge.
turn of the printer. Hold the C and # buttons and turn on the printer. When the screen goes black it will be ready to be re calibrated. there is a white dot, touch it with a pen, another white dot appears, touch it with a pen. It will continue to turn on now with a newly calibrated screen.
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Touch ADMINISTRATION then touch CONFIGURATION PAGES then MENUMAP and that will print a guide for you to look for FAX REPORTS and when to print them. You can also have a thumbnail put on a report
Yes, but it doesn't explain the fax adding/editing etc.
I figared it out. Thanks for your assistance.
this is from HP site direct. can you confirm that model number?
document.tlSearch.tx.value=unescape("")
2 product(s) found for:
- M3207 MFP
HP LaserJet M1120 Multifunction Printer
HP LaserJet M1319f Multifunction Printer
did you get a user guide with that?
status offline
