Avanti W1092F Front Load Washer Logo
Posted on Nov 21, 2008
The machine cycles to 35 min. then beeps and shows E2.
The same thing happens wioth any of the spin cycles; nothing happens and E2 is displayed.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1258
Points
Clean the debris filter.
1helpful
2answers
BOSCH MAXX CLASSIC E2 error reset, has water and drained, but the machine did not run/spin.
FROM FIXYA
Sanja Salatic NOV 29, 2009
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
I have a bwm 50 washing machine displaying e2
To fix you must do a master reset of the washing machine.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
Hope this helps
Bob
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
1helpful
3answers
Siemens WFXD5201UC Front Load Washer won't complete cycle.
I am having the same problem with my washer. Did you ever get it fixed??
Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
Washing machine not spining
You may have a problem with the rotor position sensor. This sensor is situated on the motor windings and should really be replaced by a qualified tech.
Top Avanti Washing Machines Experts
Kolbrun...
john h
Jorgie  the...
Jorgie the...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
