My Marantz was struck by lighning and I have CDs that need to be finalized. Is there any other way I can finalize my CDs that were recorded on the CDR 300
SOURCE: Marantz CDR 615: Msg: ''No CD''
I've owned one for years, and yes... depending on how many discs you burn, you may need a new tray. You can call Marantz and they will ship one to you. They will also send you a diagram of how to replace it. Pretty simple.
SOURCE: On my Marantz CDR-630, how do you erase unwanted
Which recordable disks are you asking about? "Erase" will only work on CD-RW and does nothing on CD-R.
Once you've recorded onto CD-R all you can do is add additional material to it until the disk is finalised to allow it to be played on virtually all CD players. The same goes with CD-RW, but with those you have the option to erase the entire disk and start again from scratch. You can also delete individual tracks from a CD-RW but the space does not become available for additional recordings until the disk is totally erased.
Perhaps you'll find the .pdf manual to be of use:-
http://www.vegalab.ru/forum/attachment.php?attachmentid=65482&d=1256129031
I hope that this has answered your question, all I ask in return is that you return the favour by rating my answer.
Testimonial: "Quick response, answer is clear and precise, very helpful, thank you!!"
SOURCE: Marantz CDR-510: Playback is good , recording is distorted
If this brand of media is new to you and the symptom is unique to it, I'd try a different brand.
Monitoring during record would never reveal media problems as there is no immediate playback after record as on old-school 3-head tape recorders.
I've had similar intermittent problems and I never could find a pattern to it except that it always seemed to be on low-end media. My best advice would be to try to find a pattern in your instance and make a change that avoids it. Then publish what you learned for us.
Good luck.
SOURCE: Hi.I have CD Recorder Marantz
DR-6000 only accepts CD-R audio or CD-R music discs, not the standard CD-R discs. the difference is that the audio and music discs have the OPC formatted differently and they cost a bit more because they include the royalties fee. Standard CD-R discs won't work in this recorder. The correct discs have compact disc "digital audio" logo on them.
SOURCE: I have a Marantz CDR 615 and it won't let me
What kind of error are you getting? Does it attempt to calibrate then display the entire disc as being full? If that try a blank that will tolerate recording at the 1x speed. Nowadays the only thing you will likely find are discs meant for audio recording or data discs that can record at speeds as low as 1x. If you can find some of the earlier kodak, Ampex/Quantegy, japanese maxells, etc then you will be okay. Also it may not be obvious but the cdr 615/620 will not record on cd-rw's
I bought one of those new and had nothing but trouble out of the phillips cdd2000 module that had to be replaced 3 times (3rd time at my expense of $300) but Superscope in Aurora, IL was good about support. Ironically I seam to remember a class action suit against Phillips over their very flaky cdd2000 drives.
