To round a number, we first have to find the column in question. In this question, we need the thousands column, which has a 9 in it. Next, we go to the column immediately to the right. If the number is 4 or less, we don't add one to the thousands column and set all the numbers to the right to zero. If the number is 5 or more, we add one to the thousands column and set all the numbers to the right to zero.
In this case, the number in the column immediately to the right is a 0, so we don't have to add 1 to the thousands column, and rounded to the nearest thousand, we get 39,000.
I really don't know how much, but you don't seem to be getting an answer from anyone else either. Your local dealer should not have a problem answering this one, but if they do, respond back and I will get you an answer from mine.
Well that would be... 301,500,000 rounded UP, or 301,400,000 rounded down.
BUT the second answer, 301,400,000... is YOUR answer....
The nearest hundred thousand is 400,000... hence the answer, see?
It will be 499,995. The place value would be. Ones is 5, Tens is 90, Hundreds is 900, Thousands is 9000, ten thousands is 90000, hundred thousands would be 400000.
Repeat steps 4 and 5 replacing the letter C with the letters of your disk partitions.
You have got some nice piece of virus. This is only temporary solution, as the virus will come back. Make sure you install some good anti-virus utility (Kaspersky recommended) and update it.
Few possibilities...
Incorrect settings in properties of printer.
Software glitch, Please reinstall driver.
Unplug printer for couple of minutes from AC outlet and replug back in and try.
