You can download the cam and device drivers from MSI WEB supportsite, select your model motherboard to download :-http://www.msi.com/index.php?func=downloadindex
SOURCE: MSI wind U100 built in webcam
Try to press FN key together with F6 to makes the webcam works
SOURCE: my netbook (msi u135dx) webcam is NOT wroking can
heeyyyy if you press fn and f6 it should work xx
SOURCE: built in webcam not detected..
After i ran windows media player for the first time since re-install of OS the web cam started showing up again...
SOURCE: I have an MSI U135DX. I have managed to get the
You may need to enable it in the windows settings.
Open the start menu and type in sound
Select the option with your mouse Change sound card settings.
Select the recording tab and then double click the relevant microphone.
Then, go to the Levels tab and from there you can set the volume and make sure that it is enabled.
Click OK and close the windows when finished.
