My Gorenje GV 62110 has an E4 fault (overfilled),but it is not.Have closed the door and it seems to drain but the E4 fault remains,is there anyone out there who has a solution?
Problem solved! At the bottom of the machine are two plastic covers.Take these off with a screwdriver.and the bottom of the tray acts as a condenser drip tray,I wiped it with a dry cloth and Hey Presto! no more fault,but you MUST switch off the machine firstProblem solved! At the bottom of the machine are two plastic covers.Take these off with a screwdriver.and the bottom of the tray acts as a condenser drip tray,I wiped it with a dry cloth and Hey Presto! no more fault,but you MUST switch off the machine first
You can't post conmments that contain an email address.
is it white spots or a film? if so it is the hard water and not the dishwasher. go to www.dishwasherfilter.com and get their home system. it will solve the problem guaranteed.
Hi, You may have a plugged drain hose. Clean it out That is why all lights are on. Also clean out the inside of the dishwasher where the drain is. Good luck
Hello, my dishwasher gorenje pms 60 l show specific faulty code. Both LED blinking symmetrically. Serviceman doesnt know. Please help me with this problem. Thanx.
E4 means overfilled which in practice means there is water in the tray at the bottom of the machine. Lean the machine forwards and the water will drain out and clear the fault code. chances are it will fill up again so if it repeats the leak will need to be found.
