That error signifies a fuser problem where the thermistor does not detect the fuser coming to temperature. Need to replace fuser unit, part number 008R13022, see link.
1. Check for paper on the fuser. Y remove paper N proceed to step 2 2. Check the installation of the fuser assembly, make sure it is securely installed. Y reinstall fuser N proceed to step 3 3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected N replace the fuser
That is in fact a bad fuser which must be replaced (part# 126N00321 for 110v). Replacing it is simple, open the right door and remove the 4 screws that hold in the fuser. Make sure the machine has been off for awhile because the fuser my be hot. Here is a video that shows you how. Hope it helps, and thanks for using fixya
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Whit
Item, Inc.
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
how difficult is it to replace the fuser? in the xerox 3050
thanks yes the fuser roll is what I meant
