SOURCE: to remove the lock code
Connect the iPod and go to 'my computer';
-open the iPod by right clicking on the iPod icon;
-on the toolbar menu click on 'Tools'
-select folder options>view>& check the box that says "show hidden files & folders"
-then click 'ok'
You will see a ghost folder called 'iPod control'. Open this folder to access the other folders & files contained within it.
Delete the file called "Itunes_lock"
SOURCE: forgot screen unlock code
For those forgetful people
all right guys i have a solution for this but it will require some work first:
now
u should get some thing like : Vôáijåö\féúPbíþT~ñâHzõæLvùê@rýîD as the
text but its not that con fusing to show here are two diffrent codes
the same!
]óãhjåö\féúPbíþT~ñâHzõæLvùê@rýîD
so in fact the part that matters is the first 4.... and its a 4 digit code!!
soooo i have made a guide line.. for u to match up your code with
0000
^ðàk
1111
_ñáj
2222
\òâi
3333
]óãh
4444
Zôäo
5555
[õån
6666
Xöæm
7777
Y×çl
8888
Vøèc
9999
Wùéb
now how does this help ?? well i set my code as 1234 and this is what the first 4 digits were: _òão
if
u look at the first one and compare to the guide it shows that the
first digit is 1 the second 2 the third 3 and the last is 4! taaa
daaaa!!!!
Rock on people hope this helps!!!!
~Thimolas the awesome :P
oppps!! forgot to mention that eagle btc helped me find the folder...... the little bit at the begining was from
http://forums.ilounge.com/showthread.php?s=&threadid=118446&highlight=combination+lock
SOURCE: I have ben gifted a new ipod apple a1136 but
you can search for manual here
http://support.apple.com/manuals/
theres a box to enter your serial number and it will then find the exact manual for that model
