Asda own remote model number rch7y464in1 batch number 11/28/11 asda spec code 748/111
SOURCE: ROSS 1 way remote control
1. Switch on the television
2. Hold down the mute key and red light starts blinking
3. Continue holding down the mute key while pointing the remote on the television
4. Once red light stops blinking try switching television off by pressing the red turn off key
Tested and method worked on Ferguson tv
SOURCE: need code for asda remote model#URC20-D1F
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
SOURCE: I need the codes for an ASDA remote control, model no: URC20-D1F
URC20 D1F
1. Turn TV on
SOURCE: Got an asda universal t.v remote I have lost the
if you put the remote on serch it should automaticly find the code
