How do I oil my janome MC 9500
SOURCE: Janome 3022
Hi, ALL machines will require lubrication at some point.It will require covers to be removed however. Apart from the cover over the needle bar / presser foot area, I dont recommend you try taking them off as without knowledge of exactly how, you can break the retaining clips. Cleaning out the lint REGULARLY is very important - you can use a vacuum with a crevice tool. So, remove the 'lamp' cover and needle plate, vacuum out thoroughly. Apply a drop in total to the length of the needle bar, a small amount on the presser foot shaft.Remove the black plastic shuttle, clean around it, apply a SMIDGE of oill to the 'track' on the underside of it. Thats about all you will have access to. Use proper sewing machine oil - NOTHING ELSE! If you sew a lot, get it serviced proffessionally - they will do the areas you can't access. Good luck!
SOURCE: I cannot find out how
About all you can or should need to do is remove the bobbin case and clean the lint and stuff out from under it. There is a wick in the center of the hook( the part the bobbin case sits on). Do not mistake this for lint and pull it out. Put a few drops of sewing machine oil on it. For anything more the machine should probably go to a technician as it involves splitting the case and there are some hidden screws. The machine should be serviced once a year if you use it a lot or less often if you don't use it that much. In no event should you go more than 5 years without a professional service.
sewman7
SOURCE: Janome MC 9000 Embroidery/Sewing Machine
This is the diagnistics routine for Janome 9000.
Run each test in sequence from 1 - 13, or until you find error
The results of this may not be what you want to hear, and may be why no-one has yet replied....I hope for an easy resolution for you
If you are having trouble reading this here, simply send a request via the "contact us" page on:
www.bargainbox.com.au
Martyn
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
do you have a manual?
