After refilling the cyan toner in the Bizhub 350 we started getting this error code on color print jobs. B and W print jobs run fine. But, when you run a color job the printout is delivered but the system throws code C-0F34. The door has to be opened to clear the code and then you can print again (one sheet at a time). Any ideas?
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: Bizhub 350 error code EA3226 when trying to scan to email
I changed the SMTP address from a name to an IP and that resolved it for me.
SOURCE: to enter service mode on biz hub c 500 what is the key order?
Lost my access to add employee name to scan docs Biz 500/420
SOURCE: biz hub 250 Pdf printing problem
Hi I am former Konica Tech Support for 26 years. I do some network problem. Y may need to upgrade the copier memory. or this just simple setting. on the printing side I can assure you no problem. there is a setting on the operation panel choosing if you prepared pdf when ever you to e-mail, scan to box or scan to SMB. You can delete the old print driver and the control panel delete your even the printer Icon at the printer and fax folder. Re install the printer and the printer driver. And make sure send a test print. If so happened that you don't have the print driver you can go to Konica web site and download the print driver. There are many kind of print driver. postscript driver and etc. I hope this info will help you and if not you may contact me again.
HH
SOURCE: Biz Hub c250 gives error code 3452
C3452: Pressure Heater Trouble.
Try to reset it like this:
Shut down from the main power switch (the one behind the front cover).
Keep pressed the Utility/Counter button.
Power on while the button is kept pushed.
Release the 'Utility/Counter' button only when you see the 'Trouble Reset' button on the touch screen.
Touch the 'Trouble Reset' button, a small ok should pop up underneath.
Power off, wait for a few seconds and then power on.
hw do i clear the code after door opening?
