Gak ada suara
Mainboard sya dah sya install driver y tpi audio y tidak berfunsi
If your computer came with a motherboard disc the sound drivers could be on it click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side you will have to open up the computer to check the lead attached to the rear of the input plug make clean your computer of dust using a fine air blower from a compressor making VERY sure that there is hope this helps
reinstall drivers
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
speaker right click properties then select use this device (enable) also you might check
sure the connection is good with no dust as dust causes static electricity
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
