Go to a breakers yard and get a new ignition key and lock. Hotwiring a car is not as easy as they make it look in the films. You have to get power to the ignition circuit, you also need to light up your dashboard and stuff which is key dependent. When you have done that, you have to energise the starter motor and stop it when the engine fires. And talking of fires, they can happen during hotwiring!
otherwise see this video about a hot wire
also be warned this must be your car in your name or you could be committing a criminal act by performing this service How to Hotwire Car
No. the ignition switch is not at the key its down the column at the switch which is activated by a rod. You can do it there but i would not. just call a key guy and save yourself a lot of money. If you do the wrong wires you can do a lot of damage.
Well you can just cut the wires to the ignition switch and intall a toggle switch. However, you will need a schematic to know how to attach the wires to the new switch.
cant hotwire your vechicle has the PATS SYSTEM.your keys has transponder on it.the ignition switch antenna ring and immobilizer control module and ECM read signal emitted from the keys transponder if you have no keys or wrong keys the PATS SECURITY SYSTEM DISABLE IGNITION SYSTEM CAR WONT CRANK.CANT HOT WIRE CAR WITH THE PASS KEY SECURITY SYSTEM.older cars back in 70s you could hot wire newer cars you cant.
Try this instead, find the connection where the ignition switch plugs into the wiring harness, just fallow the wires, disconnect the plug, hook up a 12v battery to the bike, find the solinoid and use a heavy gauge jumper wire to jump from the side the pos+ battery cable connects to over to the side the starter connects to. The bike should start fine, DO NOT forget to unhook the jumper wire after its started or it will ruin the starter.jumper wire jumper wwire
