Sport & Outdoor - Others Logo
Sherri Morrison Posted on Nov 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help with Craftman 5.o snowblower model @ 536885211
Will only run when pouring gas into carb. Checked fuel filter, lines, sparkplugs, float, cleaned needle, blew out passageways, primer will not **** gas. What can I check now?
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Nov 30, 2008
Anonymous
Expert
Level 2:
Answers
65
Questions
Helped
53707
Points
287
Turn on gas with the carb bowl off and float hanging and see how much fuel flows.It should be a steady stream.Have seen the seat in the needle and seat swell that only lets gas drip through not enough to keep it running.
Lincoln ranger 250 left gas in and now wont run unless feeding gas by hand. Have tried to clean carb and checked fuel lines and getting plenty of fuel
Is this a gasoline welder? I'm afraid w/o being able to look at it, I can't tell much? Is the fuel a gravity feed to the carb or do you have a fuel pump? Is there a fuel filter involved? Does the carb have a float? If so, does the float bowl have gas in it? I don't know if they have a carb kit for this, do you think it would help?
1helpful
2answers
Not getting gass but fuel pump works & gas is clean, also it has sat inside for 12 years
Well if the pump works then follow the pump fuel lines to the engine,you will find the fuel filter then replace it and will also see petrol if any in it ,if not pump isent working ,if dirty replace it and blow air back from carby to filter to clean out pipe
,turn on ign fuel should come to filter and then with new filter in turn on fuel and see if any comes to carby if ok it should start and run.
Have a goodday,
We have an old snowblower. Snowflite MTD 5/20. It doesn't start. If my son pours gas in the spark plug hole it starts but doesn't keep going. It appears to be a fuel line problem but the machine is a...
Your carb needs cleaning. It's probably old gas that has gunked the jets/orifices. Remove the carb and clean it out.
What tells you it's the carb is that you can get it to run by getting gas into the engine.
Jan 05, 2018 • Garden
2helpful
We have a craftman snowblower...wont start ..I pull the cord and get nothing...changed sparkplug but still nothing .gas leaking from carbanator ...wont turn over/...what should I check?
A big problem you have is the gas leaking from the carb. This means your float that allows the right amount of gas in the bowl for everything to run right is either stuck or the float itself is leaking (heavier than it should) and therefore lets too much gas in the bowl. The float height is critical for proper running.
Remove the bowl. Look to see if nothing sticking like the inlet needle or float itself. Turn carb upside down to the float should be parallel to carb body.(different manufacturers specify different heights but adjusting the float parallel to carb body will run good.) Remove pin from float hinge to remove float. Check to see if the float is leaking, even just a small amount of gas in float makes it heavier and therefore lets in too much fuel. It can be difficult to see if it is leaking, shake back and forth to try to find out. If the float inlet needle or float itself is not sticking I suggest you get a new float. Adjust it to be level with carb body by bending the tang that sits on inlet needle. It should be pretty well level just as is.
I suggest you try that and see what happens. But as long as you have carb apart clean it with carb cleaner or paint thinners and blow air in all ports (low pressure air). How old is the gas in the tank? If over one year old use fresh gas. Try that and see what happens. If still problems I am willing to answer any of your questions. I hope this helps a little bit. Regards and good luck.
Lawnmower sat up for a season would not crank replaced sparkplugs air filter fuel filter hose fuel pump is pumping gas to carburator but still will not start unless you pour some gas into the carburator or...
If it will start when you pour gas then its a fuel problem on some of these they have a screw at the bottom of the carb remove that and see if you have bad fuel. If that does not work then remove the carb and service it may just be a stuck float or something
My nieghber gave me a 14 inch poulan saw .but wont start.told me he started to have trouble with it and doest has the time to repaire it uses his other.i put a new sparkplug and still nothing.clean...
firstly, the answer re fuel going up the line is YES!
It sounds like a lack of compression. Take out sparkplug and place finger over cavity whilst pulling starter cord. The pressure should be strong enough to push your finger off the hole. If not, then the rings are shot or there is a hole in the top of the piston.
This will cause poor run in the fuel line to the carburetor. so the carbi is possibly empty or not full enough. Check the float level or that the float, actually floats. It sounds that that float is OK as its not flooding, but take a look anyway it may be jammed shut.
Lastly.. check the spark lead where it goes inside the body as this screws onto a screw to make contact with the inside of the leed. Get a new leed as these carbon based leeds fail after a short time anyway.
Presumne you checked it was actually sparking well?
These are the things that commonly affect chain saws and brush cutters
Please rate my help++++Thanks for using FIXYA
Check the oil hole filler and see if the oil has fuel in it. This is a good indication of poor rings and holes in psiton
2helpful
2answers
I have a sears lawnmower that was flooded recently. I bought a tune up kit and installed it. I changed the gas and oil also. when I poured in the gas it all came out the air filter. What should I check...
carburator float is stuck in the open position allowing fuel to continiously run / drain out the fuel tank into the carb and then overflow into the venturi of the carb into the engine and out the air filter. Bottom line the carb needs to be disassembled cleaned and rebuilt
4helpful
Lawnmower starts but won't continue to run
if you are getting no fuel to the plug you either have a stuck float, plugged fuel line or filter. does the gas reach the carb bowl? does the mower have a fuel pump? if so the diaphram might be bad.
Jun 30, 2009 • Garden
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
