The Freezer drain is stopped up with something. Is it a straight shot down to the pan or does it have 90 degree or other bends in the tubing?
SOURCE: Haier HTQ21JAAWW ISSUES!!!
my refridgerator seems to be workin the freezer is getting cold but not freezing its a top freezer bottom refridgerator the fan in the freezer is also not workin.i had atec come out to check it out. supposedly theres a capasitor that sits next to the compressor that he told me was bad an had to be ordered.its got 2 wires that come off the compressor that plug into this lil box.my question is could this be why my freezer is not freezing an also why the fan inside the freezer is not workin?
SOURCE: My 3yo Haier HTQ21jaaww refrigerator
things to ck . is the compressor running ? remove back the comp will feel hot if running . if its running it may have lost its gas .. / if not running but the cooling fans are . the relay on the compresser may have failed .. hope htis elps mm .. feed back pls ..
SOURCE: i need a schematic for a haier htq21jaaww
I have a copy of HTQ21AAWW Service manual that include the following :
eatures, product code explanation and series introduction, specification, safety precaution, parts and functions, function schedule, system flow chart, circuit diagram, maintenance service and troubleshooting, troubleshooting and repairs.
If you want to download the copy, I'm online now at the pay question. Click here.
Jdvillanueva
A/C WATER ON FLOOR
Could be the drain tube is partially clogged. It is usually located on the fire-wall or down towards the floor pan under the car. It is usually close to where the A/C lines go thru the fire-wall. About 1/2 inch diameter sticking straight out but may have a 90 degree elbow pointing down.
Also, it
