How to remove the spout on the E8 for cleaning:
GENTLY GENTLY GENTLY
There are two parts: You will see the top part is fixed - it does not move. Remove it first, placing fingers behind the top of the piece, and gently it toward you. It will pop loose toward you - but not off. To remove completely, simple move the top half straight up, and it will release completely.
The bottom part of the spout is trickier, but equally easy once you know how it is fastened. Exam the bottom half. See how it is fastened by sliding on rails. Facing this piece, gently push leftward on the right side of the spout. The spout is flexible, and it will bow outward enough that the right side will come off its rail, enabling you to gently pull that side out. The left side will then come off as well.
Now you can clean out all the nasty.
Reverse these steps to put it back together.
SOURCE: Jura Capress Impressa E8
Open the drawer and take out the box for the grounds. Run a rinse cycle and it should now go back into place.
SOURCE: I have a Jura Capresso
Most likely the O-rings in the thermal block are bad and need replaced. This is not an easy task to do yourself. On several machines the O-rings are oval and hard to match. And even if you find a match I do not recomend trying to fix it yourself. You will have to disconnect many wires and hoses to remove the thermal block.
SOURCE: I need a bimetal disk
My name is Mike. I thought I would help you. I have attached a Complete manual for your machine with trouble shooting tips and solutions. Please if you can rate my help and some kind words would be nice.
http://beta.fixya.com/users/mc1beanThanks so much, Mike
