Ok again old computer was Toshiba with XP. New comp is HP with windows 7. My Printmaster 18 & files were successfully transferred. However I cannot make a PDF file now. I really need this feature. I even bought PM 18.1 and cannot download it past Instsall shield. HELP! Thanks, Kath.
SOURCE: Installing a new verison of Printmaster
No,pm18 wil over come pm10 in ur comp OR uninstall the Pm10
SOURCE: I have the Printmaster Platinum Version17 , I cannot save to pdf files?
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp
This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
SOURCE: I WOULD LIKE TO CONVERT
If I was in your place I would use a direct connection if both computer's are connected to the internet ...and in the same default gateway ..its easy ..cause you can find the other computer into my network places folder..after you select the view workgroup computers task ...You will have to disable the firewall in both machines and after that you will have access on the other computer just like in my computer folder..and copy files...
If they are not on the same workgroup...than you can use a remote control program to transfer the files directly ..THis one will do the job ..,all you have to do is to install it on both machines ..open in the remote one ..and in yours..and get the ed and password offered by the program and connect to it ..after that you basically have ful access to it ..even tranfer files..
here is the program :http://www.teamviewer.com/index.aspx
If the machines are not connected to the internet than the only way is to use a large memory stick or an external hard drive ...or just get the hard drive from the one you need the files and connect it temporary to the other one ..and you will find its partition in My computer ..after that just copy paste the files in the other partition from the computer you intend to use..
SOURCE: I am using an old (but good) Printmaster Platinum
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility".
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
SOURCE: I have used PrintMaster 10
The only solution with this older software that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or are willing to upgrade to one of these versions), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. You can't have a printer installed on both the main computer and the virtual one at the same time. You will be asked to uninstall the printer if you try.
Your other option is to upgrade to PrintMaster Platinum 18.1, see http://www.broderbund.com/ for details, which is compatible with Windows 7. This will import your Printmaster 10 projects.
I hope this helps.
Testimonial: "Thanks for your help. I will investigate purchasing Printmaster 18.1."
Good Luck..............
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
