Oreck XL21 Bagged Upright Vacuum Logo
Chucky Posted on May 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Doesn't pick up
Rocky
Level 2:
  • Oreck Expert 324 Answers
  • Posted on Mar 06, 2015
Rocky
Oreck Expert
Level 2:
Answers
324
Questions
Helped
143548
Points
789
This could be a few reasons. Check and make sure your bag is not full of dirt, a full bag will make your vacuum's suction worse. Next check for clogs of dirt and debris. Check the nozzle and brushroll too. If you find no clogs and the brushroll and belt look good, it may be your vacuum fan is damaged and needs to be replaced.
Genuine Oreck Mataxalloy Fan Impeller R0008
GoodVac.com
800-775-6586
2answers
1helpful
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 • Vacuums
Head doesn't pick up stufff well
When was the last time you changed your belt? Belts should be changed once per year. We can ship new belts to you and have in a day or two.
RainVac
www.rainvac.com
800-523-0510
Dyson DC14 Animal: Loses suction when in the upright postion and I am using the wand. I have cleaned the top spongy filter. It sort of 'blows' out of the top of the cylinder if that makes sens
Hi Sharon,
I'm sorry to hear you're having difficulties with your DC14. If the machine doesn't seem to be picking up as well as usual through the wand, this may be due to a blockage in the wand, hose or U-bend. The easiest way to check for this is to follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc14/dc14-origin-iron/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
Although I note you've cleaned the filter, you might want to check you've washed it as shown in the video below - in normal use, this should be done at least once every 3-6 months. Wash both parts of the filter in cold water without detergent, and allow at least 12 hours for it to dry before replacing it.
This should resolve your issue, but for any further assistance, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Why did the red power light go off yet the dyson 25 appears to be working fine
Hi Carol,
I'm sorry to hear you're having difficulties with your Dyson vacuum cleaner. As DC25 doesn't feature any indicator lights, your machine is likely to be DC28.
If the machine continues to run and pick up as normal, but the on/off switch indicator light has gone out, it's probably best if you get in touch with us directly so we can provide further assistance. You can call us free on 1866MYDYSON, or email [email protected]. We'll look forward to hearing from you.
Kind regards,
Jack
After cleaning the vacuum it is not picking up and you can not use the nozzle
I'm sorry to hear you're having difficulties with your DC14 Animal. If the cleaner doesn't seem to be picking up as well as usual, please follow the steps shown in our online troubleshooting guide to ensure everything is correct with the machine:
http://www.dyson.com/support/help.asp?article=626&product=DC14-ANIMAL_US
Hopefully this should help you resolve the issue without further assistance. However, if you've tried this and are still concerned, please get in touch with us directly by calling free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
2helpful
My NEW Dyson won't pick up lint that sits on the top of the carpet. When I stoop down to pick it up it's not stuck and lifts easily. Why doesn't the brush scoop it up?
Sorry to hear you're having difficulties with your DC24. You might find it helpful to follow the steps shown in our online support guide to make sure the cleaner isn't blocked:
http://www.dyson.com/support/help.asp?article=1120&product=DC24-ALLFLOORS
If you've tried this and are still concerned about the cleaner's performance, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to check everything is correct with your cleaner. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 • Vacuums
Top Oreck Vacuums Experts
john h
hsapiens
Level 1 Expert
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
