Clarity Professional C4105 Amplified Cordless Telephone Hearing Aid Compatible Logo
sharon bolz Posted on May 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you program new numbers in speed dial on the clarity c4105 phone
How do you delete and program speed dial numbers
Vitally Alcher
Level 3:
  • Master 1,645 Answers
  • Posted on May 15, 2012
Vitally Alcher
Master
Level 3:
Answers
1645
Questions
Helped
467022
Points
3209
Delete the old ones and add the new ones one by one .
How do I change the speed dial keys that are already programmed?
  1. In the phone, press the Menu key.
  2. Click View Speed Dial List.
  3. Click a contact or phone number.
  4. Perform one of the following actions:
    • To change the contact that is assigned to a speed dial key, click Edit. Click a new contact.
    • To assign the contact to a different speed dial key, click Move. Roll the trackball to move the contact to the new speed dial key. Click the trackball.
    • To delete the contact from the speed dial list, click Delete.
How do you delete and add speed dial numbers
Push star on all the numbers then add the numbers you want and push add.
1helpful
How do I delete a speed dial number
Lift the head set. Press PROG button twice. Then press MEMORY then the speed dial number. Hang up. Done. Or..Lift the head set, press PROG, enter a phone number you'd like to set to speed dial, press PROG, MEMORY, the speed dial number (1,2,3,4 etc), then hang up..
4helpful
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
3helpful
2answers
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Meridian norstar want to delete and enter new numbers
If you are asking about Outside Auto Dial numbers (a "speed dial" number programmed to a button), follow these steps:
1. Leave the handset down
2. Dial "Feature (star) 1"
3. Press the button to be programmed
4. Enter the "speed dial" number
5. Press button under "OK" on the horizontal display.
The group of 12 buttons on top of an M7310 phone are Dual-Memory buttons, each can hold 2 speed dial numbers. When you press the button, you are using the Lower Memory location. When you press the Shift button (triangle-shaped button on the right) and the a Dual-Memory button, you are using the Upper Memory location. Good Luck!
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Do you havew to delete existing phone numbers in Clairity W-1000
Yes I did solve my problem. Just lift the receiver, Push program key, enter full number and push program key again, then push the button above the space you want to store the new number in and hang up the phone. Did not have to delete the old number. Thanks.
1helpful
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
6helpful
3answers
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Top Clarity Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Clarity Health and Beauty Expert? Answer questions, earn points and help others
