When I put the car in drive and go the doors lock automatically, but when I stop with the van running and try to use the power lock to unlock them they will not unlock. They won't even unlock when the van is off, I have to use the manual unlock button.
SOURCE: Radio, Key auto door lock/opener, interior lights not working.
Most likely is a fuse. There is a fuse box at the end of the right side of the dash. Open front passenger door and there is a cover that says fuses on the end of dash. There is also a fuse box located under the hood at the right front of engine compartment. It should have a cover with a round knob in the middle of it .Unscrew the knob to remove cover.
SOURCE: Automatic door locks / 2001 Chevy Suburban
Your book should give you program options for the door locks If your fob wont work either you got a relay for the door lock bad it is located in the fuse panel push the door lock button and find the one that is clicking
SOURCE: Venture van power door problem
It sounds as though one of the proximity sensors is faulty. Also try giving the tracks for the door a good shot of white spray lithium grease. The door may be binding enough so that the emergency reverse is kicking in.
SOURCE: power door lock on the chevy venture 2000 don't
check the system fuse and or circuit breaker. check the switch wires for damage and loose connections. check the switches for continuity. remove the door panel(s) and check the actuator wiring connections to see if they're loose or damaged. inspect the actuator rods if equipped to make sure they arn't bent or damaged or loose connections. the actuator can ce momentarily. a discernible click indicates that the solenoid is operating properly.
SOURCE: 2004 Chevy Venture Passenger side sliding door
It sounds like you've got a broken wire on the drivers side door. Usually this occurs at the flex point of the wiring harness. Peel back the outer covering carefully exposing the wires inside. Repair any broken or those about to break. Solder & retape or shrink rap with heat gun.Hope this helps. Good luck!
