Kohler 12 kW Emergency Power System - 12RES-L Logo
Harold Wrede Posted on May 09, 2012
Kohler 12 RES - Unit fails to start occasionally. Attempting a manual start by placing switch in run position, cause a loud click, but no cranking. The panel says CC. This morning I put a jump start battery on it, and it cramnked right over, but the unit's battery shows a full charge. Is it possible there is a dead spot in the starter motor?
  • Harold Wrede May 11, 2012
    I have no replaced the battery and tightened the starter connections, and on the first manual start attempt, it wouldn't crank. I noticed that there is slight buzz/click from the motor, and then a loud click from the gas solenoid, and then it normally cranks and starts. I then repeatedly tried it and it started every time, and went back an hour later, and it also started normally. So it's intermittent, which is the worst case for testing.
  • Joseph Moor
    Joseph Moor Apr 14, 2019
    I have replaced the starter. Have a new relay but cannot find where is goes. Checked everywhere from control panel to engine compartment. Does anyone have a picture?
Freddy E.
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 23, 2012
Freddy E.
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2570
Points
I finally solved the intermittant starting problem on my Kohler 12 RES by replacing the strater and the starter relay. I was also experiencing the occassional OC indication, red blinking LEDs on the ATS, and intermittent non-starts during the weekly exercises. The problem happened during power outages a couple times also. If I flipped the start switch between auto and run quickly the generator would occasionally start. Once started, the generator runs fine. I ordered a new starter, which included the starter solenoid. By the way, don't worry about the genuine part thing..the old starter was a Delco made overseas. I ordered a new starter online for $85 (6744N) and it was indentical to the genuine Kohler starter. Replaced the starter and it improved the problem but did not totally solve the intermittent starting. Ordered the starter relay (GM49746) replaced it and the problem is solved.
  • Cynthia Colley
    Cynthia Colley Jun 19, 2016
    Freddy K...Can you tell me how to access this to replace it? you can reply to my email kimbercin at the American online ..thanks..
1helpful
Kohler 12.5 res gen. Battery is good. Get OC code. If I reset auto switch by clicking off, then clicking run, then clicking auto it will start. Any thoughts on this issue?
OC is Over Crank which generally means it cranked and cranked and failed to start. Turning the switch off and on again is the way to clear the fault. How long is it taking to start whilst cranking? It should start within 8 seconds
1helpful
12 RES - Control Panel Dead With New Battery
If it won't start in manual, you have a short and/or a bad control board. Make sure battery polarity is correct, did you disconnect battery charger before removing old battery? If not charger can push DC volts over 20V and can damage control board.
Kohler 12RES only starts on second try
Check gas pressure. Oc is over crank. Means tried to start but did not.
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Kohler 12K RES where are links for the installation /setup of the controller? thanks
The 12RESL has no user setup. That's part of lower cost on the DC 2200 controller versus an ADC 2100 or ADC-RES controller that came with the 12 / 17 / 18 RES models. Here is a link for the ADC 2100 Operation / Installtion manual though. http://www.scribd.com/doc/60318571/Kohler-8-5-12RES-Install
1helpful
3answers
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
2helpful
When I try to start my generator the code oc comes
Check battery volatge while you are cranking engine if voltage drops below 9 vdc you have a bad battery. If it doesn't you probable have a bad starting solenoid or a bad ground at the starting solenoid.
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
