Sony MHC-GX555 Mini Hi-Fi System Shelf System Logo
Anonymous Posted on May 09, 2012
My sony MHC-GX470 keep saying eject - Sony MHC-GX555 Mini Hi-Fi System Shelf System
5 Related Answers
Anonymous
  • 10594 Answers
  • Posted on Jan 13, 2009
SOURCE: I have a Sony MHC
I think grooves are dirty / clogged in sled section of lens mechanism. There is flexible wire between lens and circuit board and this should also be checked as it can be cracked or misaligned.
Below is exploded view of lens in MHC-GX470 and marked area to be checked or cleaned.
junit80
Jermaine Johnson
  • 81 Answers
  • Posted on Jun 26, 2009
SOURCE: I have a Sony MHC-GX470 stereo...it will not play
the mechanism is bad or in human terms the motor that excepts and moves the disc has gone out i reccomend taking it to a repair shop to get a estimate because it may jus be cheaper to replace it.
Jonathon summesfield
  • 285 Answers
  • Posted on Aug 12, 2009
SOURCE: sony mhc-rg330
Get a lens Cleaning Disk and put it into the CD Player, there could be foreign objects on the lens itself, these and other shelf systems all have one common problem... Dust.
jon
Anonymous
  • 1326 Answers
  • Posted on Jan 24, 2010
SOURCE: sony 3 disc changer mhc-gx880 has broken belt. How
You have to open the unit with screws in the back and push it out by hand, there should be a series of gears that you have to spin for the tray to come out. You may be able to gently push it by hand to come out.
Ironfist109
Iron
  • 3018 Answers
  • Posted on Mar 24, 2011
SOURCE: how to reset my sony
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
I have a sony HCD-gx470 stereo an it will not go to the next song by itself how can i fix this
hi, if you are reffering to the cd player section, then check the program or repeat feature. make sure that none of these features are enabled. if this does not help then activate the "master reset" procedure in your user manual. lastly check beneath your unit for any transport locks/screws applied to the cd mechanism. cheers.
Sony hcd-gx470 manual
My Sony Mini MHC-GX470 have been working until a power outage yesterday and now it will start coming on the goes back to standby mode. I can hear it going through the system, starts the radio and immediately goes to STANDBY.
I need HELP!!!!!!!!!!!!!!!!!!!!!!!!
My CDs wont play. I click CD & i want to listen to my CDS in CD1 CD2 & CD3 but they wont play.They say "No Disc".
You could either try getting a linse cleaner for your Sterio. Or take it apart and Clean it, There might be alot of dust and dirt inside so it makes it hard for the laser to read the disks.
How to record from cd to cassette tape
It's in the manual (available for free download at retrevo.com) on page 18.
Cd player won't play. A "Mech Failure" message appears.
Something might be fried. take it apart or take it to someone to look at it.
I have a Sony MHC-GX470 stereo...it will not play cd's...when you load a cd in it comes up with "mecha error"...the cd changer will not move between cd 1, cd2 and cd3 either.
2helpful
I have a Sony MHC GX470. It has been working great since I've had and the sound quality is awesome but since 2 days ago the cd player keeps skipping and it'll restart the song and skip again or it freezes....
3helpful
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
