NEC Electra Elite DTU 16D-2 Corded Phone Logo
Posted on May 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When call fowarding what is a destination station?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • NEC Master 102,366 Answers
  • Posted on May 09, 2012
NEC Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443445
Points
622693
The destination station is the number to which you want the calls forwarded.
Call forwarding redirects (or forwards) calls to your phone to another phone. This other phone is the destination.
Good Day. We are travelling on the Premier class train. We wish to take the Gautrain to Park Station. What is the distance between the gautrain platform and the park station lounge?
Hello, Vanessa -
You posted your question on Fixya.com, a website intended for asking and answering questions on how to go about REPAIRING THINGS.
I am answering from the USA. Since the Gautrain runs in South Africa, I have no idea of the distance from the Gautrain platform to the Park station lounge.
You have probably arrived at your destination by the time I am replying to your post.
Just in case . . . this is the link to the Gautrain Contact Us page, where you will find a toll free phone number you can call for information:
https://www.gautrain.co.za/contactus
Best wishes.
2answers
Avic s1
hello sir,
Portable Smart GPS Navigation comes with 3.5-inch Touch Panel Display, 2GB Flash Memory, Bluetooth Wireless Technology, and Scroll Wheel
  • 2GB Flash Memory contains the map data of entire US and Canada
  • Just unpack and use it � no PC connection is needed for startup
  • Future map data updates will be available by SD card � just load into the built-in SD card slot and the update will begin
  • Quickly set a destination by address, zip code, destination history, and more
  • Search for a gas station, restaurant or coffee shop using the POI Search � destinations are sorted into categories for short-cut searches, or use the touch screen to type in the name.
thanks for allowing us to help you
I am trying to use the manual single station on the control. It will not change from station 1 to station 2 or 3. Please help.
PDF
Owners Manual - Chevrolet
https://www.chevrolet.com/.../Manuals.../2k15mylink_volt_ca...
ChevroletLocalizing-U.S./Canada-7639743) - 2015 - crc - 3/21/14. 2015 Chevrolet ... BluetoothAudio . ... manual in the vehicle, so it will be there if it ... button or by using a singlevoice ... 1. Preset Buttons (1-6). 2. DEST (Destination). 3. NAV (Navigation). 4. ...station. RPT (Repeat Navigation): Press to repeat the last voice guidance.
[PDF]SAMRTmini manual BUILD.indd - Source FM Transmitter
https://sourcefmtransmitter.com/wp-content/.../SMARTmini_manual1.p
1helpful
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Sharp MX-M350N Error CE-03--We changed ISP providers and can't get Inbound routing to an email working again. I changed smtp server in "Network Setup". The "Connection Test" passes for SMTP. We can email...
CE-03 is a communication error, obviously. Your print card and your new SMTP are not talking together. Your system is probably OK at this point, but is unable to communicate well with the new network system. Work with an IT department to resolve this.
2helpful
Setting destinations on a prius gps
ok hit the destination button on the side of the screen it will provide you with options on how you would like to input your dest. decide if you would like to enter the adress of and destination or you can can also input the destination by the name lets say you were looking for wal mart you would enter wal mart in the poi name screen (poi stands for point of interest) it will then bring up a list of the closest wal marts to you also telling you the distance and direction you would then hight the one you want to go to on the touoch screen obviously by touching it and then hitting the enter button that will highlight red i believe on the bottom of the screen your last option is to serch by poi category you would hight poi categoury on the destination screen it will then bring up a screen of categories such as health care and hospital police and fire stations government buildings such as city halls libraries post offices court house things like that there is a shoping category you would pick clothing department stores and such there is one for closest service shop gas stations recreation such as parks golf courses and such once you decide wich category you want you simply hit show list that will highlight on the bottom of the screen and it will show you a list of the closest things in that category to you
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
