Neff 24 in. S5456 Built-in Dishwasher Logo
Posted on Nov 20, 2008
Neff dishwasher s5433xogb/29 pump keeps running
My dishwasher finished washing little red light came on to say it had finished but pump was still running and would not turn off until i pressed the switch off and when turned back on pump keeps running and cant select a program what can i do to fix it
  • 4 more comments
  • Anonymous Nov 30, 2008
    Yes I have the exact same issue. Even when I reset the program buttons the pump is still running. Anybody got any ideas??
    Ok pssible solution is that there is water in the anti flood sensor area which keeps the pump running. How do i gain access to this sensor as there is no panel on the front of this machine & it is fully integrated
  • Anonymous Dec 01, 2008
    Hi pete,
    I believe we have different issues. My issue is where the pump keeps running when there is nothing to drain. I throw water in & it drains it away no problems there, but the the pump just keeps on running even after program reset.
    As for your issue i believe these machines fill through mains pressure. Have you checked what pressure you are getting from the supply. This is easy to check just turn the valve off remove the supply hose & use a water pressure tester which is a piece of pipe with a gauge & tap on it.
  • am8181 Dec 03, 2008
    Us too. The pump keeps going and I am sure its the flow switch that jammed. It happened after the drainers were blocked and i unblocked them using a plunger
  • chif Dec 18, 2008
    I have the same problem - pump keeps running , but no water in machine - how do you access the flood area?
  • hot water Jan 08, 2009
    my pump keeps running, but water I add to the dishwasher does get pumped out to the drain, so i guess there are no blockages. A repair man says, without looking inside the machine, that I need a new motor at £150 plus labour, but I dont see anyone has suggested this solution. I am worried that if I buy one and it doesnt fix the problem then I will have wasted my money-any advice please
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8076
Points
Our Neff Dishwasher S5456X0 the pump was running all the time and the solution 1 worked. We removed the front panel under the door and the the flood camber was full of water. Drained it out with a sponge and the dishwasher is fine. Thanks
  • Anonymous Oct 30, 2010
    This solved the problem on our Neff Dishwasher also. All I did was to tip it backwards to drain out the water it it worked. ;-)
Anonymous
Level 1:
  • Posted on Jul 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8076
Points
Hey people. I had this same problem with Dishlex dishwasher today. Pump kept running after cycle was finished and water emptied. Discovered the anti flood device was active. Removed bottom front panel. Removed galvanized access panel behind bottom front panel. Drained water from anti flood water collector using sponge. (It's a small flat open container with a styrene float and micro switch near the bottom of the cabinet directly under the chamber sump). Problem solved, no cost! Yey! This could also be accessed by removing the right hand side panel.
Anonymous
Level 1:
  • Posted on Nov 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8076
Points
My neff dish washer won't seem to draw water from the supply it sounds like it is trying but stops after about two minutes of trying. i have checked the filters they are all fine it is about eight years old do you think it is time for a new one or is there something else I can check I have poured boil;iong water in a few times and the pump is still clearing it out???
Anonymous
Level 1:
New Friend:
  • Posted on Mar 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8076
Points
My NEFF S9W1F integrated dishwasher pump continued to run although no water was left in the drain sump. Subsequently, I carried out a repair myself and saved a fortune; here is how I repaired my machine.
After doing a bit of research on line, I found that the cause of the continued running of the drain pump was caused by the water leaking into the lower sump (normally dry) causing the a micro-switch to activate and trigger the drain pump to cut in and continue to run even after resetting the machine.
I removed the machine from under the unit, be carefull at this stage as the sump is full of water and this will spill out when the machine is moved (so be sure you have plenty of towels down to soak up the water). I got some help and lifted the machine into the garage and removed the two side panels, these are easily removed and I connect the machine to a water supply and ran the dishwasher and it was evident that the leak was from the circulation pump.
In order to replace the seals within this pump you will need to remove this pump from its location. To do this you will need to remove the metal strip that runs along the bottom of the main door and the two torx head screws that secure the upper section to the bottom sump on the right side, once this has been done pull the right side down just enough to get the pump out. You will also need to cut the metal securing hose clip that is on the outlet of the pump and also remove the three electrical connections, once you have done this the pump can be removed with a bit of force and manoeuvring.
The pump comes apart quite easily by clamping the motor in a vice and screwing the plastic pump body anti-clockwise this will then lift clear and expose the pump impellor you will need to remove this to gain access to the shaft seal, you can by a new seal kit for about £42 from here : http://www.espares.co.uk once you have replaced the two seals and impellor you can rebuild the pump and refit back into its location in the reverse order, I used petroleum jelly to help fitting the hoses and replaced the hose clip I had cut with a standard jubilee clip, once fully rebuilt refit under the unit and hang up the rubber gloves and give yourself a pat on the back.
Tools required: Torx heads, small socket set, new seal kit and jubilee clip, petroleum jelly.
Anonymous
Level 1:
  • Posted on Apr 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8076
Points
Try tilting the machine back with the front feet adjust ments ,just a cm or so will do . level sensor in drain pump thinks theres still water in the machine .If this doesent work get a service Guy !
NEFF s51e40x1gb/29 dishwasher button 7 flashing
Taken From the Manual (https://media3.neff-international.com/Documents/9000816278_I.pdf)
If the appliance stops during dishwashing or does not start for no obvious reason, first run the Abort
programme function (Reset).
Terminating the programme (Reset)
1. Open the door.
2. Press START button 9 for approx. 3 sec. until all displays go out.
3. Close the door.
The remaining programme sequence for draining the residual water takes approx. 1 minute.
2answers
NEFF S5443X1GB/29 My dishwasher isn't completing it's full cycle. It seems to be washing ok, however towards the end of the programme instead of going quiet whilst drying and then gurgling quickly and a...
Does the drying occur? If the heaters are not working it may need the temp to be high this may stop it moving to the next part of the program ?
Nov 02, 2013 • Dishwashers
My dishwasher takes water but does not start to wash it pumps the water out and takes new water and that's going forever
SOUNDS LIKE THOSE LITTLE ROACHES GOT INTO THE CIRCUIT BOARD AND FRIED IT.
MAIN CIRCUIT BOARD HAS BEEN SHORTED OUT
I have a Neff Dishwasher S5446x0/29 FD 8109 460056. It started making a whirring noise and when I looked it was not emptying the soapy wash water. I stopped the machine and manually drained the water out....
if the pump is not emptying properly it will think its still full, they have a sensor in the bottom that tell the machine that the system is empty and to begin next cycle.
3helpful
I have a Neff Dishwasher S5443X2 and the dishwasher tablets are not dissolving. The tablet door is open when the machine finishes but most of the tablet remains. We tried using detergent but still the same...
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
1helpful
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
3answers
Dishwasher not washing very well
usual reason is that the arms are not rotating freely - they only turn by water jetting out of angled jets. blockages are not always obvious as blockage material tends to go out of sight when water pressure off. favourite culprits are rice and sweet corn
Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
Top Neff Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Tracy
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
