1998 Volkswagen Golf Logo
Posted on Nov 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wet passenger side
I have recently noticed a small patch of wetness/dampness on the floor of my golf on the passenger side!i have mats down but the mat does not seem 2 get wet underneath the mat it is occuring! so i guess its not the seals on the door or sunroof as the matt wud get wet? am i right if thinking it is coming from underneath the car? it is also damp wen it doesnt rain so any ideas wud be much apprieciated??x
Anonymous
Level 2:
  • Expert 153 Answers
  • Posted on Nov 21, 2008
Anonymous
Expert
Level 2:
Answers
153
Questions
0
Helped
77801
Points
399
I believe the problem is a leak in your heater core. The water would run down the inside of the firewall or near it thus running under the mat.
  • Calwyn Palmer
    Calwyn Palmer Nov 30, 2013
    I had the same problem with my '05 QX56 after heavy rain. It seems that the sunroof drainage hole was blocked, allowing the water to overflow the drainage channel. I diagnosed the problem by opening the sunroof after I opened the door to see water dripping on the passenger floor. Once the sunroof is rolled back, look for a puddle of water in the front corners of the sunroof drainage channel. I solved the problem with a zip tie I found in my glove compartment.
2helpful
Could my heater core be causing my passenger floorboard to get wet
No,What year,make and model is your vehicle Carol,when the heater core leaks,it will be the driver side floor board that gets wet,are you using your A,C,Theirs a hose on the passenger side that the A.C. drains to the outside ground,could of came loose,it's on the passenger side.
Why does my Citroen xsara picasso 2hdi 2003 have some sort of oil leak seeping through mat by passenger feet
If the Air Conditioning unit is leaking refrigerant, that would explain the oil. There is oil in the refridgerent.
Toyota 2006 Corolla wet floor mat passenger side
It sounds like your heater core is done. That is in a tight spot in behind the glove box. Get a new one for around $60.00.
2010 Ford F 150 Carpet is always wet under floor mat on driver side
I have a 2005 f150 just notice that the driver and passenger side mats are wet. I had my windshield replace almost a year ago and went back recently to have them recheck the seal. What else could t be need help
1helpful
2answers
Carpets are wet in foot wells after all the frosty weather, and not just when it rains. Any solutions?
Have you been adding any coolant? You could have a leaking heater core, which will usually leak to the inside, wetting the carpets in the well. Most American cars locate the heater core on the passenger side of the firewall, so a leak will typically show up on only the passenger side floor. I once had an Audi that had the heater core mounted just about dead center on the firewall. When it started leaking, both sides of the well(s) got wet.
2helpful
Soaking wet floor mats - '98 Mazda Protege ES
drain pipe from the interior ac unit ,look for rubber outlet pipe outside firewall passenger side and unblock the end
Wet floors on passenger side after it rains.
Is it possible the water is actually coming from the A/C evaporator case, whose DRAIN IS CLOGGED ? The water produced by the A/C then leaks out of the case, down under the carpeting, then depending how vehicle is parked, can flow to the rear floors and carpet. Hope this helps
I have a 2007 Nissan Frontier XL 4X4. I recently noticed that the passenger side floorboard is wet UNDER the floor mat. Could this be the air conditioner backing up?
yes, your a/c drain is most likely clogged up causing the water to come inside the cab. see your nissan dealr. warantee issue. 3 years 36000 miles.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
