Kenwood DDX-6019 Car DVD Player Logo
Anonymous Posted on May 09, 2012
Kenwood model ddx6039 monetore&dvd recever in my car and it is need a password
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
201
Points
Hello
could you solve your problem? if so, please tell me how, because I am in the same trouble
  • Anonymous Jun 08, 2012
    hello
1helpful
Kenwood DDX7017 Car DVD Player "Reset password
During the code request mode, while holding the DISP key, press and hold the Volume UP or DOWN key for 3 seconds.
NEED PASSWORD FOR KENWOOD MODEL DNX51120...THANKS
You will need to visit an Authorized Dealer or service center for that product to get the unlock code reset. You can find a dealer listing on their website, or call them.
Need password on kenwood ddx8019
1helpful
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Kenwood kvt-715 dvd
if its a kenwood thin you can use any kenwood remot and push 55222277 this shold reset it..
2answers
Help
do u know the model number and brand
1helpful
Zoe
The only cure that I know for kenwood security code issues is here
Dont know if it will work with your model or not. Let me know if it does :)
regards
robotek
Kenwood DDX6039 DVD In Car Unit
there is a wire attach to ur handbrake system. it should be tv on when the handbrakes is pulled on most of the unit. it'll goes off again when the handbrake is release & drive.
1helpful
4answers
Kenwood kvt 717 dvd
I think this may be it, here: http://www.partstore.com/Part/Kenwood/Kenwood/KVT717DVD/Kenwood/Kenwood/J84015005/New.aspx If not, do a search for your model number on the same site. They have over 100 replacement parts for that model.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
