SOURCE: DWF 413 dishwasher
What about the pump, did you checked it ? Does it drains water out the machin ?
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
SOURCE: dishwasher problems brandnew
I am having a problem with the soap dispenser either not opening or it does open and the soap does not melt.
SOURCE: E1 Error on LG Dishwasher (LD-2040WH)
Maybe the blockage is somewhere else. How about removing all the trays from the dishwasher, in other words, empty it from all racks and dishes and try it again
SOURCE: Whirlpool dishwasher wont change cycles
wow, good move with the heating element. most folks don't know about how that relates. if that stuff is good, it must be the timer. or at least the small motor which turns the timer. good luck
