Oops! A system error has ocurred.restarthing show kher rha hai iska koi solution dejyeOops! A system error has ocurred.restarthing show kher rha hai iska koi solution dejye
You can't post conmments that contain an email address.
mY Dear: First: restore your Phone Settings IF Restart problem not Solved So Secend Option: Please Format Your Phone we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure. *#7370# or *#7780# Default security code is 12345 release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card. If Problem Not Solved So Very Best Solution: flash new software install in the phone problem will solved quickly
First make sure that you have data plan enabled. Second, check in Data portion of you settings 'data packs' enabled then there would be no problem in browsing
maybe your memory card is already full just delete videos,musics or message or transfer it in the computer and restart your phone you wont see it again
If you have take new mobile means in the box you will get a CD that is
called as a PC suite you should instal the pc suite for your system
after that you call the services provider for you smart phone there you
can ask that person to send you the settings for internet.They will send
you the settings at that point of view you should save that settings
after that you should make some changes in your pc this information will
be provided from the service provider then you should switch off your
phone for a few minutes after that you switch on then connect your phone
to your pc through data cable or bluetooth and now you can enjoy using
the internet.
var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
