ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Default 6 Digit Security code: 000999 or 1122 Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved OR: If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
Hi , The master reset code for nokia 1200 with IMEI no 359843013133715 is Security Mastercode: 2313214552 . Hope this solves your Question. Thank you for using http://www.fixya.com to solve your Question . Please feel free to Ask your Question on This site.
Regards.
default PIN for nokia is 1234. However, if you forgot your PIN. You can do one of two things. You can have your phone flashed, by call NokiaCall the Nokia Care Contact Center:
Telephone: 1-888-NOKIA-2U (1-888-665-4228)
TTY/TDD: 1-800-24-NOKIA (1-800-246-6542)
This will ERASE everything on your phone. If you want to unlock your phone to use another simcard (different carrier) Contact your current Mobile carrier for the PIN Code. You will need to verify the IMEI#. Most GSM Mobille companies will provide that free of charge.
the security code for your nokia 1200 is 12345, if it does not work
then the master code for IMEI 359820012968226 is 0510516213
if this does not work, then you need to send your set to any service center
for factory setting, take care [email protected]
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code: Master Reset Code Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times. Which is the one that you want? The default security code for Nokia is 12345
sir, how to unlock my nokia 1200? my IMEI is 356790027125281.
My Nokia 1200 can not be unlocked since I last swoped my sim card,the phone requires a Security Code...I can not remember correctly my Code.
Is there a Unlock Code I can use on phone?
sir, how to unlock my nokia 1200? my IMEI is 356408020388091
