Hi, you can purchase original batteries from amazon. click here and take a look: GP Alkaline Battery Lr1 1 5V 2 Pack. I hope this was helpful. Cheers
It takes a 1.5v model N1
SOURCE: How can I start a small Quartz clock?
The first thing to try would be to test the battery. If the battery is good the problem may be the mechanical works need to be started in motion. If it has swinging parts try to get them swinging. If it has hands set the time on the clock. Hold the the clock in your hand with the face towards you and rotate it clockwise a few times to get the gears moving. Sometimes just letting it sit upright for a day or so will be enough to let the clock start working. I hope this is helpful to you.
Carol.
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
