Question about Vizio L37 Television
Vizio VX37L 37'' LCD HDTV Television not turning on
Bought noted TV at Costco June 2007. Once we had an instance where it would not come on for some reason but next day it was fine. Worked perfectly until about 3 months ago when we turned off the TV with the remote to go out for a while. When returning tried to use remote to turn on and it would not come on. Also tried the main power button on the TV with no results either. Vizio Tech support was absolutely worthless. Any ideas? If you can offer any help, please do so in the most "TV Repair for Dummies" mode as that is what we are............HELP
  • 1 more comment
  • kenshido Nov 28, 2008
    I had the same thing happen. We powered the set off, went to bed, and the next day, and since hten, have not been able to power it back on. Happened two months after the warranty ran out, go figure!
  • Gordo722 Jan 19, 2009
    Good Evening
    I have a brand new VX37L HDTV that was manufactured in December 2007. Two weeks ago I finally installed a wall mount and connected it for the first time. I've only been using it for two weeks and now it will not power up either by the remote or the manual button. When I try to power the TV on with the Vizio remote absolutely nothing happens but when I attempt to power the TV on using the manual button on the right side of the TV the VIZIO light turns white for about 2 - 3 seconds and then it immediately turns amber again. Can you help me with this problem?
  • Martin1J Mar 01, 2009
    I am experiencing the exact same problem.  The T.V. was working fine until I hooked up a new DVD player to it this morning and when I tried to turn the T.V. back on - no power.  I've tried everything.  I unhooked the new DVD player (which works perfectly on our other two T.V.'s), I've tried a new power cord, I've moved the T.V. to a new outlet (even though the DirectTV box had no power problems working out of the same outlet), and I changed the batteries in the remote control (even though I could tell it still had batteries because a red light comes on every time I push a button on the remote - even though it doesn't turn the power on for the T.V.
    The problem is definitely with the T.V. itself.
    Does anyone have any suggestions?
    Top Expert:
  • Vizio Master
  • 12,962 Answers
Unplug set and hold and press the power button for about a minute. Replug set and turn it on. If nada, then the issue is with the power supply of the set. Given its age and the high cost of repairs it might be more cost effective to get a new set.
Posted on May 03, 2017
6ya staff
SOURCE:
Dewayne Turner
  • 87 Answers
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
Anonymous
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Posted on Feb 19, 2008
Anonymous
SOURCE: emerson remote control with vizio 37" tv
Try 004, it worked for me
Posted on Jan 08, 2009
Anonymous
  • 1077 Answers
SOURCE: No Power to a Vizio VX32L
My best guess is to check for blown fuses or the power board when bad inside the TV.
If that doesn't work, looks like you'll have to pay a repair shop to find out what's really going on.
Sorry I can't help you further.
Posted on Feb 03, 2009
B52Tony
Tony Nguyen
  • 96 Answers
SOURCE: Vizio LCD 37 Inch Turns Off Randomly
This could be a main board or power board issue. replacing main board and/or power board should resolve this problem.
Posted on Jun 16, 2009
Vx37l blue screen
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 29, 2016 | Vizio 37" vx37l hdtv widescreen lcd/tv...
Vizio base stand model vx37l
You can get replacement Vizio remotes from Walmart, $10. As far as the pedestal, I can't locate one either. I would suggest checking Ebay frequently. I recycle LCD sets and come across rare pedestals. If you would like, visit our website, click on Contact US and leave your contact info. I will put you down on our Wish List and contact you if we get the pedestal in stock.
www.back2lifeelectronics.com
Jan 10, 2013 | Vizio VX37L Television
I have a Vizio 37" TV (VW37L HDTV 10A) bought in
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ ///
Sep 03, 2017 | Vizio VW37L 37 in. LCD TV
Tv Vizio VX37L HDTV 10A
Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
Jul 19, 2010 | Vizio VX37L Television
Our 3 year old Vizio plasma TV just made a popping sound and the screen went blank, then about 30 seconds later, a horrible piercing buzz started and we had to unplug the TV to get it to stop...Any ideas?
It just happened to me on 4/7/10. My vizio p50hdm made a popped noise & did not turn on. I purchased the tv at costco on June 2005 w/amex card. I pulled my amex statements from 2005 then called costco with my member # and they found the transaction. If you purchased the tv before 4/2007 the item is grandfathered with the 100% customer garrantee. After 4/2007 the return policy changed to 90 day money back return 2 year warranty and you get an additional year if you purchase w/amex card for a total of 3 years. Be very nice to the Costco people even if they give you an attitude on the return of tv. I got a credit for $2200. I just purchased a samsung led tv 46 series6 back lit & internet. Amazing Technology. & I Love Costco
Mar 30, 2010 | Vizio L32 32 in. LCD HDTV
Vizio VX37L HDTV black rectangle in lower right corner
Turn off or modify CLOSED CAPTIONING settings
Jan 24, 2010 | Vizio VX37L Television
TV shows orange light but doesn't work
Have you tried taking it to Costco for an exchange? Other than their strict return policy on many electronic items, they are very good about customer service. They may make an exception if you take it in and talk with a manager in person.
Jul 09, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio L37 37 in. HDTV LCD TV
I had a similar problem with my Vizio Model VX37L HDTV and replaced the main board myself for $160.00 which I purchased new on Ebay at ShopJimmy.com. The symptoms all of sudden started by the screen going blank except for a rectangular banner across the top that resembled a UPC code only garbled. No sound. I actually had to pull the power cord to turn off the TV. I was able to turn on the set normally but the TV menus did not come up. Since the TV was 19 months old and no extended warranty I checked with Vizio support and Sam's Club but no extended warranty=no luck. I did have an estimate for repair for $900 from a company Vizio recommended but a new one goes for less now. About 42 screws and a half a dozen pin connectors I replaced the main board. The set is working again better than ever. I don't know if I call my self fortunate or not since I did have a problem after only 19 months.
Jul 11, 2008 | Vizio L37 Television
Vizio L37 Television Logo
221 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
