I have a Samsung Series 450 Plasma TV. Direct TV HD receiver, A Samsung HT-TZ512 DVD surround sound system, A Panasonic DMR-ES30v DVD recorder. I can record shows off the TV, Both systems will play DVD's on the TV. If I play a non copyrighted DVD in the Samsung Surround sound system, it will play on the TV, the Panasonic will not record it. Anyway to hook this up correct? I could do it before when I did not have HDTV. I think It all went through the DVD recorder, but now that I have a HDTV receiver I cannot run the cable into the DVD recorder. The HDTV Receiver box has 2 Cables, the DVD recorder only has 1
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
How are you hooking up the hd sat box to your panasonic dvd recorder? Also why don't you hook up your dvd recorder with component video instead of a/v cables cause you said your tv is on a/v1 which most of the time that is red,white,yellow plugs on the tv? Component would give you progressive scan which is double the resolution. One other possiblility is that your samsung dvd player might be blocking the red,white,yellow jacks if it is connected to the tv hdmi. Some players will do that because the hdmi connection is copy right protected even though the disc isn't so you might also want to try to run component from the samsung dvd to tv and then red,white,yellow to the dvd recorder. I have had personal experiences with that issue. You also said you can record off tv which makes since because the directv hd boxes do not block the other a/v outputs when connected to the tv hdmi. Anyway this is some ideas and if you are recording off sat try to plug dvd player into same plugs sat worked on as well just to make sure your all your inputs are working on dvd recorder. Good luck!
this solution did not work.
the direct TV plays on HDMI 1, The samsung Plays on HDMI 2, the dvd recorder plays on AV 1. the DVD records from the TV on AV 1. I hooked the red, white, and yellow from the Samsung to the dvd recorder. the chanel was IN 1, nothing recorded.
