Timex 5B841 Wristwatch Logo
I can't adjust my tmex watch
Cannot change the time
Gc Watches ' World Time - YouTube
? 2:53
https://www.youtube.com/watch?v=wxXNcb3VjYM
Sep 6, 2013 - Uploaded by Ceasmania Shop
Ceasmania este cel mai important site romanesc privind vanzarea ceasurilor si bijuteriilor marca Guess ...
Guess Gc Watches Sport Class XXL Review - YouTube
? 4:04
https://www.youtube.com/watch?v=hZxtnZFdjnA
May 8, 2013 - Uploaded by aBlogtoWatch.com
aBlogtoWatch watch review of the men's Gc (Guess Collection) Sport ... Show more ... Not like a cheap watch that gets scratches over time..
Guess Watch Guide on How To Adjust Time & Use ...
? 1:37
https://www.youtube.com/watch?v=V2FPk-6mD7g
Nov 29, 2011 - Uploaded by Jade Bryan Jardinico
Download Manual for all Guess Watches: ... Guess Watch Guide on How To Adjust Time & Use Stopwatch (W17540G2 50m ...Show more
[PDF]GUESS Watches
Jan 10, 2016 • Watches
Second hand sticks to minute hand diesel dz 4021 watch
Likely the two hands are touching. A watchmaker can adjust them, shouldn't cost much,
6helpful
2answers
I Have a fossil 10 atm watch & the date doesn't change automatically so i change it manually but then half way thought the day it changes the date
Your watch is 12 hours out of step.
The date changes every second time the hour hand passes 12 O'clock.
Your watches' second pass is at midday instead of midnight, so to make it operate correctly, you need to wind it on 12 hours. The date will then change at midnight.
I have a digital watch SHARP made that says SUNDAY when really it is TUESDAY how can i get watch to say the right day?
Take a look at your watch. While models and brands vary, you'll find a few things in common on almost all of them. First, they'll have different modes of operation. A typical digital watch may have modes for time, stopwatch, date, alarm and timer, to name a few. Look on your watch for a button labeled "mode." Press it several times to see what's available. Typically the watch will display the name of each mode as you push the button repeatedly. When you've found the mode you want to adjust, stop there.
  • 2 Look for a button that is labeled "set" or "adjust" on your watch. The location will vary, depending on the brand of watch you own. Press in and hold this button. After a few seconds, the time (or whatever mode) you have selected will begin to flash. In most cases, you'll need to select the item you want to adjust (minutes or hours) by pressing "mode" again. Once the portion you want is flashing, you're ready to adjust it.
  • 3 Press a button to advance the parameter (hours or minutes) that you've selected. This button may or may not be labeled. If it isn't labeled, you'll have to experiment with different buttons. Once you've set the first parameter, change to the second by pressing "mode." Follow the same routine to adjust. To exit, you'll typically press the "set" button.
  • 4 Use resources available to you. There are thousands of digital watch styles on the market, each with slightly different setting methods. When you buy a watch, tuck the manual away in a safe location for reference. If you don't have the manual, do a website search. Most major manufacturers keep their manuals online for easy future reference.
  • Jun 28, 2011 • Watches
    1helpful
    I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
    If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
    Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
    Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
    Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
    1helpful
    2answers
    After time change day, i cannot adjust my watch time to normal time casio 4757 wvq-143e
    Actually this is a simple procedure for a watchmaker or a person that changes alot of batteries, you don't need to send it anywhere, for the price of postage you can get someone to reset your watch, It is not actually a button but a spot on the circuit board that is shorted with tweezers to the positive side of the battery. This procedure is usually done when you install a new battery.
    2answers
    I need to find replacement band for Freestyle Men's Rockaway watch
    Google search your watch, choose from list of suppliers etc.
    Top Timex Watches Experts
    Paul Bade
    NOEL
    NOEL
    Ngoro
    Are you a Timex Watch Expert? Answer questions, earn points and help others
