I have separated the engine unit from the arm. I also removed the hex nut and removed the spring assist pieces. Not I cannot get the rest of the pieces off to get the cover off so that I can get to the rope to untangle it. The piece I am trying to remove looks to be part of the spring assist. On it says OFF and an arrow. Also says 3/8. Any ideas?
SOURCE: starter pull cord
take a light and look into the clutch hole
you will either need a torx or star type nut driver or a allen or hex head nut driver to fit in the hole and turn the screw ccw while holding the flywheel.
Make note where all comes off and all goes back in reverse when fixed.also after you remove the clutch housing you will be stareing at the clutch shoes next and it will have markings on which way to turn it for removal.
SOURCE: line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
SOURCE: can not remove spool to replace string
If it's like my Ryobi, the alignment arrows are for feeding in string, not removing the spool. When aligned with the arrows, you should be able to insert two pieces of line into opposite sides of the housing. The ends of the line will come out of the spool next to a tiny hole. Put the end of each of the two lines into the holes, then pull the two lines from the outside. This will lock the ends of the line into the tiny holes in the housing. Now you can turn the housing by hand to wind the lines onto the spool. I think it will take about ten feet of line (on each side).
Alternatively, spin the bump stop out of the assembly. This holds the spool in, so when the bump stop is removed, the spool comes right out.
I hope this helps.
SOURCE: can't get the head off troy-bilt weedeater to replace the line.
Threads are left hand. Hold the black wheel and use large plier or pipe wrench to turn the knob cloclwise
