Three year old riding mower with Briggs & Stratton engine that smokes when using
SOURCE: can't find oil filter model
there's 2 possible models... depends on the length of the filter..
one is 2 1/4" long Model no.492932 and the 3 1/4" is no. 491056
you should be able to order online at briggsandstratton.com
SOURCE: engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
SOURCE: Snapper Briggs and Stratton riding mower
It's mounted in an enclosure directly over the carburator.
SOURCE: I have a riding lawn mower. It starts up ok, then
Is the crankcase full of fuel? Remove the dipstick from the engine ( do not wipe clean) and walk away from the engine and in a safe manner hold a lighter to the dipstick. If the dipstick lights and burns then there is fuel in the oil.
If there is fule in the oil then drain then change your oil and rebuild the carb being sure to replace the inlet needle. It is also a good idea to install an inline shut-off valve in the fuel line. Then start and run it again. It will take about 5-10 minutes to burn out the residual oil/fuel from the exhaust. After that it should clear up and not smoke anymore. Dont forget to shut the fuel off when the unit is not in use.
