Hi my Exxcel 1400 S Express is 8 years old and the programmes have started over running by about 50 mins. No error codes. Shows cycle length as the correct time but doesn't end since still rinsing and then indicates 50 mins remaining. Any advise much apreciated, Sue
The main control is not advancing properly and needs to be replaced,
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: Hi our Bosch exxcel washing
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is
trying to pump the water out before the Spin cycle, but can't. Usually
this is caused by a foreign object that is obstructing the impeller. See
my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it
does not, then you may need to replace the Drain Motor. Which is a easy
task.
Kind Regards :-)
* If this solution helped you, please rate it
SOURCE: my fridgedaire affinity washing machine washes the
it could be that your rinse water valve has gone turn off all power and take the top off you can see the water valves at the back of the machine if you have a multi meter you can test the valves for continuity if ok then your filter might be blocked try the filter first
