My whatsapp says it has expired and it needs to be upgraded. I have tried doing so, but still it fails to download. I deleted it after 3 attempts of upgrading it, then i tried downloading it again but it is still failing to. Please help me, how can i get/download this application back to my phone?
Dear mnqobim,
For S60 symbian operated nokia mobiles: The whatsapp messenger is free for 1 year and its the trail period.And after the trail period i.e., 1 year you have to purchase it for $0.99 USD/year.So,if you've used it for 1 year then the trial period is over and you gotta purchase it.
For S40: I think your phone C3 is S40 and whatsapp for your mobile is not currently supported by the company and also the carriers Airtel, Idea, Vodafone, Tata Docomo and possibly others in India are currently unsupported.So wait for some time until the support is extended by the company
Nokia C3 0715167337
SOURCE: Formatting N95 Nokia Phone
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
You could try this, but don't hold much hope:
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Or try:
Hard reset code *#7780#
SOURCE: N73 Software update 4.0839.42.2.1 failed
remove the cable and before update make a backup then download the nokia software updater from here
http://europe.nokia.com/get-support-and-software/download-software/device-software-update# then wait about 15 minutes thats what the softare tells after that your phone is updated if
SOURCE: my nokia c3 says file
this simply means that your phone does not support the (maybe) the version of the application..
just goto sharemobile.com on your mobile phone, so you can download another one
hope this helps
SOURCE: HELLO Im trying to download whatsapp
Hello Zain,
The whatsapp application is not compatible with Nokia C3.
You can also visit the link provided below for more more information :
http://store.ovi.com/content/62616
SOURCE: I can't login in eBuddy
Sir,
First of all you may read proper instructions what are the functions you have in your cell phone if Java application is not there you can downloaded. Without Java you can't do the needful.
ramesh
Mine is a nokia aska 201 and I'm having the very same problem as u r.
asha*
Im using e72 my whatsapp expired when i download it again it says i must check time and a date
