The two large burners stay on high even when you move the dials lower. If you turn the element off, and then on to the left, the problem resolves. What needs to be replaced? Thanks!
The dials you mentioned are called infinite switches and if they control, or regulate should i say the amount of power applied to the burner, so those are the parts you need to replace. You can order online or go to a local appliance parts store, just make sure you take your model number with you, not the number in your owners manual but the model off the machine itself.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
SOURCE: Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
SOURCE: heating element stays on when turned off
The thermostat (that is the dial that you turn to energize the heating elements) is the only thing that connects power to and disconnects power from the heating element. It is bad.
You can unplug the unit and remove the thermostat. Take it to a parts supplier and get a new one and install it. Your problem will go away.
If you would like to see a wiring diagram...click on this link:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255301.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Thanks very much! We'll look into that right away!
