Sony
SOURCE: sony bios password
One of the ways around it is to remove the CMOS battery on the mother board and wait about 10 minutes before putting it back in, but if its the companies that's your decision..it'll reset BIOS and clear the password..you can't use any password cracking software because it doesn't boot up enough to recognize your CD drive.
SOURCE: Sony vaio VGN-S56GP pawer on Bios password
Hello, I can unlock ANY SONY VAIO bios password (PCG AND VGN MODELS). If anyone have questions feel free to visit www.laptoprebirth.com or send an emailto [email protected] WE SUPPOR OTHER BRANDS LIKE ACER HP COMPAQ TOSHIBA ASUS GATEWAY DELL FUJITSU SIEMENS SAMSUNG
SOURCE: How to reset BIOS password on VGN FE880E
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
SOURCE: How do I replace Sony laptop keyboard VGN NR498E,
go to the following site. http://web.archive.org/web/20040310140428/http://www.vaioshutdown.com/f/0.html
SOURCE: Sony Vaio VGN-NR498E recovery disk
Hello
Well, the recovery disks won't allow you to go to your present system. The recovery disks are designed to put everything back the way it was when you bought the computer, minus all your applications and data. If it's your data that you need then a reputable repair service like mine can slave your hard drive to another system and recover all your data (not applications), provided the hard drive has not electronically or mechanically malfunctioned. Again, a reputable repair person can tell you the status of the hard drive.
Thanks
