The serial number is 15439 L. The bottom of the lighter says Cartier Paris.
To look up the steel ligter serial number is very easy ,I specialize in buying and selling Cartier watches. I've seen fakes with all the correct marks and a serial number, but that doesn't mean they are legitimate. If the watch was registered by Cartier when it was sold or if it has been sent in to Cartier for service Cartier will be able to verify it is authentic, but be aware that if the watch was not originally sold in North America or was not registered when sold (fairly common) it can still be authentic. Some sellers offer the Cartier quartz model for sale and only state that the watch has a quartz movement, but fail to mention if it has a Cartier quartz movement. If it has a replacement movement in it the watch is technically authentic, but not original and is not worth as much as one with an original or a genuine Cartier replacement movement. The biggest mistake I've seen amateur Cartier buyers make is using the Cartier micro-script signature on the Roman numeral to verify authenticity. Indeed this is a good indicator, but not the best indicator as there were many Cartier watches produced prior to the technology required to make the micro-script possible and not all Cartier watches have Roman numerals for the dial to have the micro-script signature. Furthermore, the micro-script is not always located at the same place and if the dial has been refinished it may not appear at all. Another common problem is actually caused by language differences, i.e. "all original versus "authentic". A watch can be authentic without being all original. Unless someone has owned the watch since it was new and it has never left their sight it is impossible for them to state the watch is "all original" as a part could have been replaced at some point in time -- even without their knowledge. Your best bet is to buy from a reputable seller even if you have to pay slightly more money. -- Cartier_Specialist
Watches are one thing, but getting info on a Cartier lighter serial number is impossible unless you know the store in which it was sold. Cartier lighter serial numbers are assigned at random and even the Richemont Technical Center (Richemont owns Cartier) doesn't have info on lighter serial numbers (I've tried). The usual advice applies, what is the reputation of the seller, and is it to good to be true.
SOURCE: is my cartier watch real or fake
You can distinguish real or fake.the real is heavy than the fake,fake is lighter.the color the real one is not to shine is dull,the fake is very shiney compare to real,the metal they use the real uses stainless,titanium and gold.The fake is nickel plate or zinc metal.the engraving the real is deep seated engraving,the fake is on the top only not so deep.I can't say your watch is real or fake,basing on serial number,the emitator can emitate the number.I gave you a tip how you know the real or fake.
SOURCE: how can i check a serial number for a cartier
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
is it real lighter
