My T325 only works on every other call. If I turn it off then back on again so it connects to my Motorola Droid Pro it will work for one more call. If I make a call without "rebooting" the phone will show a call in progress but there is no audio on the T325. I can hear the call if I switch to the phone's speaker phone.
Hello, friend! I happened to see you with this problem, I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional unlock tools.
They are free to consult, I hope that the programmers I recommend can help you
SOURCE: is there a firmware update
I'm having that exact same issue, with my Samsung flip phone. Works perfectly for one call, but have to turn it off, and back on again to work again.
Just curious if you have a Samsung too?
I did try it with another non-Samsung phone, and it worked like a charm, without issue...so I have to assume it's my phone?
SOURCE: I'm having a problem with
Try to reset the system and then try pairing it again.When you reset all paired device to the speaker will be wiped off.start paring the speaker with your Droid x
To reset :
press and hold both Reverse and Forward buttons at the same time until speaker system resets.
Thank You
SOURCE: NEED DIRECTIONS FOR MOTOROLA T325 BLUETOOTH IN CAR
You can download its quick start guide from this location.
Hope it is what you were looking for.
Anyway, please, let me know if you need further informations.
Regards,Carlos
SOURCE: I need the User's manual
Sure! You can download its quick start guide from this location.
Hope it might suit your needs.
Regards,Carlos
Sarah
The Motorola Droid is a a Verizon phone, not straightalk.. If the Original then it is long out of warranty. We have had multiple Droids so I'd like to confirm which one. It could be the battery. If the original droid, then it has a depleted battery. In some cases charging it overnight might recalibrate the battery. If it has been used past its charge cycle times then it will need to be replaced.
You may also consider going to Motorola Owners Forum
Mark
Motorola Support
