Vacuums Logo
debbie nelson Posted on May 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My rotating brushes have stopped rotating
My less than 1 year old vax vx2 rotating brushes have stopped rotating and i am unable to use my vaccum cleaner
  • Anonymous Mar 12, 2014
    Vax power vx2
    Vax power vx2 power switch not working
VacuumSpot
Level 2:
Novelist:
  • Expert 171 Answers
  • Posted on May 18, 2012
VacuumSpot
Expert
Level 2:
Novelist:
Answers
171
Questions
0
Helped
79944
Points
286
Almost certainly you have broken a drive belt. It is not a big deal though just turn it upside down and remove the base plate you should be able to access the belt from there. You should be able to get a belt pretty easy from an online retailer like vacuumspot
5 Related Answers
Anonymous
  • 120 Answers
  • Posted on Jul 06, 2009
SOURCE: Less than 1 year old Bissell Healthy Home 15 in. 12 Amp
that machine is made to do that, there is a safety switch in the base of the machine that shuts the brush off when the handle is in the upright position.
Anonymous
  • 281 Answers
  • Posted on Apr 05, 2009
SOURCE: Bissell Vacuum Cleaner
on some brush rollers you can take the ends off to clean out the debris i have a revolution myself.just pull on each end and see if you can get the ends off.
Anonymous
  • Posted on Nov 25, 2008
SOURCE: Brushes on My Hoover Steam cleaner will not spin
We had same problem,Had to have bearings replaced at hoover store/service center. If you bought it within the last year it is under warranty and you wont be charged.
Anonymous
  • 701 Answers
  • Posted on Oct 28, 2009
SOURCE: Brush will not spin any longer
Even though the belt may look okay it can still be stretched. If the belt is stretched then it will not turn against the resistance of the carpet. I would try changing the belt. You can get the belt for this model here:
http://www.vacbelts.com/bissell-pet-hair-eraser-belt.htm
Anonymous
  • 244 Answers
  • Posted on Dec 02, 2010
SOURCE: Took Roomba apart to clean and now the pick up
You can go to www.iRobot.com . This is the roomba website. You should be able to find replacement parts, customer support, videos or the Roomba product, and more.
When you cleaned your Roomba, did you also clean the wheel wells and outer most edges of the brush brush cartridges? There can be lint, threads, and at my house, cat hair, wrapped around the outermost edges of the brush cartridges.
I hope my suggestions help. If so, please contact Fixya and rate my solution.
Thanks and Good Luck!
Vax Dual V spin scrub brushes do not rotate any more
They're powered by the suction. Check that the brush switch is on. Otherwise, the brush head can be taken apart for cleaning. It's probably clogged up with hair, threads, etc wrapped around the shafts.
Apr 22, 2019 • Vax Vacuums
2answers
My vax power pet 6 keeps cutting out after about 10 seconds, sometimes less. i have changed the filters, theres no blockages, the sunction is great til it cuts out, ive even changed the on/off switch.
I had the same problem, after a few seconds the VAC cut off try turning off the Brush Roll mine then stayed on. the problem is with the rotation brush in the bottom of the VAC you need to take the cap off the end of the brush (the side where you can see the metal pin) it is not easy to get off but it can be removed. if its like mine it will be full of hair, this makes it hard to rotate. once cleaned put the cap back on, put the rotating brush back and it should work. This has resolved my problem.
Jan 13, 2015 • Vax Vacuums
Vax Problems> The front brushes on my Vax V124
before it stopped working did it smell like burnt rubber at all if so its the belt
Jun 05, 2013 • Vacuums
Took Roomba apart to clean and now the pick up brushes start and stop during cleaning. The vaccum is clean but will not constantly spin. Runs great but pick up brushes start and stop. Is there a number...
2answers
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Top VAX Appliances Vacuums Experts
john h
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
