After starting my computer dell inspiron 530 the fan keeps on
SOURCE: Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
SOURCE: Solid Amber light when starting the Inspiron 530
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
SOURCE: My Dell Inspiron 530 wont turn on
yes buy a power supply. I have seen hundreds of computers that have gone through storms. Remember a Dell usually uses a special power supply.
For a good deal look on ebay for your specific model, They almost always have "Buy it Now" deals.
SOURCE: Turning on DELL 530 the orange led remains on
I'll save you 3 hours on the phone with DELL. Same problem.
If you are OK with this, turn power off, discharge system by pressing on button for 5 seconds. Identify the slot for the phone jack/modem. Remove it. Plug in and turn on. If that is the problem, turn off and insert the card in the adjacent slot. They asked that I replace the motherboard, so if you're under warranty, call them.
SOURCE: solid amber light ON Dell Inspiron 530 desktop.The
Hi
Please try the following
1) Remove ALL wires from thw back of the PC
2) Press and hold the power button on for approx 15 seconds
3) Replug only the mains power wire and the monitor cable and then retest
Please advise of outcome
I hope this has been useful
