I have had an extremely similar problem with my Comcast Motorola DVR and Sony Bravia with HDMI connection. For months I would lose picture/keep sound when changing from a non-HD to an HD channel. The solution that I found is that there is a setting in the cable box setup that will likely fix your issue. Turn off your cable box leaving the TV on. Quickly press the Menu button on your remote to get into the Box setup. Make sure that 4:3 Override is set to "Off" instead of 480i. I believe this will solve your problem.
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
